trip computer calibration after installing cavalier LCD tach
by vaggelis00 » Thu Sep 30, 2010 2:15 pm
how can i make my trip computer work as it was before installing the LCD tacho?
any help would be good. thanks
vaggelis00
Re: trip computer calibration after installing cavalier LCD tach
by Fraz » Thu Sep 30, 2010 2:46 pm
what you mean by "work" ??
by vaggelis00 » Thu Sep 30, 2010 5:54 pm
i mean that the range is wrong, the instant consuption is only liters/hour and doesnt change. so something is wrong. how can i fix it?
vaggelis00
by Fraz » Thu Sep 30, 2010 6:15 pm
so you only get an "F" on the range function ...as far as I am aware the only way this will be corrected is to have the chip of the Fuel computer the same code as the dash chip ...what chip is in the dash??
not sure what you on about with the instant consumption, that works fine on mine just the range dont work
by vaggelis00 » Thu Sep 30, 2010 6:59 pm
no i get a number for range. when i start the car there is a number but it doesnt change as i drive the car. i get no F signs.
vaggelis00
by Fraz » Thu Sep 30, 2010 8:10 pm
have you changed the wire on the fuel computer as per the instructions
On models with fuel computers you may have problems with the Range display giving inaccurate information. Unplug the fuel computer connector and move the black/blue wire from pin 26 to pin 8
by vaggelis00 » Thu Sep 30, 2010 8:24 pm
as far as i remember i did this yes
vaggelis00
by Fraz » Thu Sep 30, 2010 8:30 pm
have you tried another fuel computer?? I have the LCD as does a few others and the only fault on the fuel computer is the range function does not work, all you get is the "F" on the range, but all other function work as they should
how accurate is the speed on your dash?? have have you checked with a sat nav the actual speed to what is shown?
by vaggelis00 » Thu Sep 30, 2010 8:56 pm
its not accurate. i have bought a pulse converter to make it work 100% accurate. i get no F signs at all. in instant consuption when you drive the car does it change from gal/h to gal/m?
vaggelis00
