how to remove rubbers?
can anyone tell me how to remove the the rubber that is above the doors and goes all the way back to the back window?
any instructions would be great, looking in hanes book cant see anything on it, as i want to renew them or has anyone got a good set i could have?
Re: how to remove rubbers?
theres a push plug thing on the door check up near the windscreen then the rest is just a pull out job
i was about to put "grab base of c**k and pull at the top of rubber" then i read the full question
this is waht i want to renew
take the rubber off along the top of the door and youll see screws that hold on a shinny bit then there are screws under that that will need to be taken off you will also need to take the rear window out to get to the ones there
so not as hard as i thought?
I've heard Phantom saying it can be a nasty job.
i would rather take the engine out on a busy bus route with a skate board than have to take the rear window out and back in with out f*****g up the plastic trim...........have fun
i bet you never do it or if you do start it youll never put it back in yourself
v6 steve wrote:i would rather take the engine out on a busy bus route with a skate board than have to take the rear window out and back in with out f*****g up the plastic trim...........have fun
i agree with steve as it can be a right fiddly job to do
mine with the window out
