Whurring on turning left
Re: Whurring on turning left
Robs-se wrote:True, found out from someone that as i have aftermarket brakes its not applicable to mine but if i went back to standard then i would have to get some fitted.
that dosnt make sence, im sure Mr C told me if it isnt there how can he fail it
Nope doesn't make sense to me either, in fact i totally agree with you Steve. I have had a mechanic doing wheel bearings on it and he didn't say anything about them not being there and he's an MOT tester. Surely if its a fail he would have told me at the time.
Fraz wrote:
all brake discs must have a rear shield or back plate
Method of Inspection i. presence and security of brake back plates, wheel cylinders and callipers
Reason for rejection i. a brake back plate, wheel cylinder or calliper securing device loose, missing or excessively deteriorated
http://www.motuk.co.uk/manual_350.htm
This must apply to rear brakes as the back plate is the only means of securing the brake shoes. What purpose does the front plate serve? None that i can see in my opinion
This is sorted now as well, been a good day. Driveshaft not tight enough
i know someone elses northcape v6 had the same problem when he bought it,,,,,,
where is the panda hiding anyway
I missed tightening it when i put the strut back on, excited about having a car that didn't crash over speed bumps
vinny_69 wrote:someone callive been dicking about with a 2.5 for a week
Tell us more
oh, is it a tractor?
never mind
i'm sure Damian will let you sit in a real 2.5 on Saturday mate
i'm sure Damian will let you sit in a real 2.5 on Saturday mateNothing succeeds like a budgie with nae teeth
2.5 diesel
