wheel wobble?
wheel wobble?
i've got a problem every time i go above 50mph the steering wheel is wobbling ,seems to die down abit
above 80mph though
,apart from the obvious ,buckled wheel,wheels not balanced properly does anyone
have an ideas as to what the problem could be??? gona take wheels of this week and check and see if there is
spigot rings on them Any help greatly appreciated guys as its driving me
above 80mph though
Cheers-
DOD
Re: wheel wobble?
tracking could be out
Re: wheel wobble?
You've covered the obvious causes already Dod, The fact it gets worse then better again as you get faster tells me it's badly balanced.
Re: wheel wobble?
while youv got the wheels off check the balljoints are lower arm bush's also check the tyre pressure
Re: wheel wobble?
Thanks for the quick reply's guys , i'll get the tracking checked and get wheels
re-balanced see if that helps
DOD
Re: wheel wobble?
and also the spigot rings are there (if required)
Re: wheel wobble?
balancing would be my first port of call...
