Big Brakes
Big Brakes
ok guys a wee brain teaser for you
im putting big 4 pot callipers on the turbo from an other car (not goig to spend £1200 on a LMF kit) what ones do you think will fit without too much work, or what cars have you taken bits from to make your own kit
Re: Big Brakes
mmm, i will ask my vaux mate Sheldon when i see him Steve.
Re: Big Brakes
iv started a set today but not sure if there is an easer way or if someone has done it already and i could get sizes from them
Re: Big Brakes
has any one fitted Fait coupe turbo callipers ? i got a set and had a wee dry fitting on saterday and by my mesurments i will need a 19" or 20" wheel and a 350mm disc to make it all work,
Re: Big Brakes
I have Billet4 4 pots on mine with a 285mm disc on a 4 stud pattern and 17inch wheels are a snug fit
Re: Big Brakes
you will need to register and search for brembo 4 pot calipers and brackets for sale by a guy called montyfox
Re: Big Brakes
which audi ? and do you know they fit or is it just a suggestion
Re: Big Brakes
What sort of power level is the standard turbo brakes good for? as much as I'd like to have nice gucci 4 pots I don't fancy splashing out if there is no real need.
tiff_lee
Re: Big Brakes
my brakes are good and stop me from silly speeds but heat up after time and then fad, on the Highland tour last year i had smoke belching out from the a couple of times after doing the private road stages
thats why im wanting to upgrade mine if not a good set of pads and disc would be fine for most turbos
thats why im wanting to upgrade mine if not a good set of pads and disc would be fine for most turbossteve
Users browsing this forum: Bing [Bot] and 31 guests
