strutbrace
strutbrace
by craigyboy » Thu Apr 07, 2011 8:56 pm
can anyone tell me if its worthwhile fitting a strutbrace and do you notice any difference in the road handling?
Re: strutbrace
by Callyman » Thu Apr 07, 2011 9:08 pm
It depends on how hard you drive around corners.
It will certainly assist in maintaining the suspension geometry, which would also help with tyre wear, but a potential downside is that if you where to take a shunt in one side of the car, the strut brace could transfer damage the the other side too
Ive had one on mine (currently off being tweaked/painted) and dont notice any difference, but i don't throw it around that hard.
Re: strutbrace
by craigyboy » Thu Apr 07, 2011 9:24 pm
cheers mate,theres a few things i want to get done to the old bus before the show at Billing! :)
Re: strutbrace
by v6 steve » Thu Apr 07, 2011 9:27 pm
iv got front and back on the turbo not sure if i notice any diffrence but they look good
Re: strutbrace
by garyb » Fri Apr 08, 2011 12:19 am
craigyboy wrote:can anyone tell me if its worthwhile fitting a strutbrace and do you notice any difference in the road handling?
If by rear strutbrace you mean simply fitting a straight bar between the strut tops then no, waste of time. They aren't load bearing sites. Stiffer ARB & bushes should be the first target if looking to improve handling with the rear.
A quality adjustable bar across the front struts is worthwhile. You will notice the difference if you drive enthusiastically...
garyb
Re: strutbrace
by Fraz » Fri Apr 08, 2011 12:50 pm
yes fitting something like the whiteline rear antiroll bar is supposed to be better, have had a front strut brace for years..dont thing it does that much (and I do chuck it round corners) but it does look good
Re: strutbrace
by v6 steve » Fri Apr 08, 2011 7:53 pm
a wee pic of my rear one it might not do much but i like it
Re: strutbrace
by craigyboy » Sun Apr 24, 2011 2:11 pm
like to inform everyone that someone else has been using my account!! and I am not from Glasgow! I have now changed my login details.
So the person who has been posting under craigyboy pls get your own account!
Re: strutbrace
by RobbieV » Sun Apr 24, 2011 3:38 pm
Locked until further notice.
