car was all covered in snow......
Re: car was all covered in snow......
you dont want acid cleaners, and you would have a separate sponge for wheels and body work
I believe you Fraz and yes It was reference to TFR but surely this must be the same stuff,Don't understand how it dissolves dirt but doesn't touch the wax
KERR_SE9 wrote:I believe you Fraz and yes It was reference to TFR but surely this must be the same stuff,Don't understand how it dissolves dirt but doesn't touch the wax
There are many different type's of snow foam.
it does not dissolve dirt for a start, it removes the dirt with the foam, as I understand it the foam attracts/encases the loose dirt and the foam then drops off the car and takes the dirt with it....and that is why it wont really clean the car fully, but it does help and will remove a lot of it...it is not a replacement to actually washing the car
it is not a TFR
it is not a TFR
Cool,Either way the car looks good
I think the steva method of cleaning cars is best
