help needed with my v6 please
Re: help needed with my v6 please
Don't think my keys got a chip as iv had others cut and they worked plus its the old style vauxhall key (like old cavs and novas)
rich30mex wrote:Don't think my keys got a chip as iv had others cut and they worked plus its the old style vauxhall key (like old cavs and novas)
If your ECU has the PN code on it then it doesn't have the Immobiliser function.
can anybody tell me were the fuel relay is located
Drivers side lower kick panel.
any body now how i test the fuel presure to make sure its running at the right presure
rich30mex wrote:any body now how i test the fuel presure to make sure its running at the right presure
With a pressure gauge ?
Or depress the pin on the schrader valve to see if petrol comes out
RobbieV wrote:rich30mex wrote:any body now how i test the fuel presure to make sure its running at the right presure
tryed a preasure gauge it didnt fit there is fuel there but i dont no what preasure its at
this thinks realy burning my head now carnt find anything wrong
right been at the car again striped both the heads off and had them tested they are both fine.
is there any way to test the ecu and if it is faulty should the ecu light on the dash be on
yes i was getting round 210 to 220 on all 6 cylinders
Are you 100% sure the timing is right?
callyman wrote:Are you 100% sure the timing is right?
yes mate all the pully marks line up perfect
Sorry if im repeating someone or myself here but are all 6 plugs getting a spark?
edit, how spooky was that? lol
i would put money on it being timming iv spoke to your Dad a couple of times and im sure he has done it right but thats what it sounds like, iv got a nice little red top you could stick in it
