pass or fail??
pass or fail??
well my car is in getting its mot @ 10 am today so i hope it passes but knowing my luck it will fail
how many adv and how main fails do you think ill have>
Re: pass or fail??
here is the fails and advisorys
Reason(s) for refusal to issue Certificate
Rear Registration plate insecure (6.3.1b)
Front no beam pattern Headlamp aim aimed so that it dazzles other road users (1.
**DANGEROUS**
Offside Front no beam pattern Headlamp aim aimed so that it dazzles other road users (1.
**DANGEROUS**
Nearside Rear Brake hose ferrule excessively corroded (3.6.B.4e)
Offside Rear Brake hose ferrule excessively corroded (3.6.B.4e)
Front flexi pipe Exhaust has a major leak of exhaust gases (7.1.2a)
Exhaust emissions carbon monoxide content after 2nd fast idle excessive (7.3.D.2b)
Exhaust emissions Lambda reading after 2nd fast idle outside specified limits (7.3.D.2b)
Advisory Notice issued
Front to rear both pipes Brake pipe slightly corroded (3.6.B.2c)
Offside Front Brake pipe slightly corroded (3.6.B.2c)
Parking brake Your vehicle has only just met the required park brake efficiency. It would appear that the braking system requires adjustment or repair. (3.7.A.10)
No rear seats fitted at time of testing
Rear bumper insecure
Hi/level brake light incomplete
Both fuel pipes at offside rear heavily corroded advise replacement
Re: pass or fail??
now for the lights i was told they faild because they should have a distinctive straight line the go up to the left
mine is just a "round beam!" these are the ones i have and was told i could land planes with my light and was aked i must get flashed all the time !! erm never
http://www.madmotors.co.uk/lighting/ang ... -eyes.html
Re: pass or fail??
thought you told me they stopped the test
Re: pass or fail??
they stpped it and re started
dont have the report on me i got that of the web for my mot
needing parts quickly & help as he wants £300 incl mot!!!
Re: pass or fail??
mate you should have at least have fixed the back bumper
and registration plate before the MOT
Re: pass or fail??
was told they would secure it BEFORE the test
Re: pass or fail??
Wire brush the ferrules and paint them with hammerite.
Get the flexi replaced and this will sort out the lambda and make sure the car has had an oil and air filter change and stick some cat a clean in the fuel tank to sort out the emissions problems. As for the lights, they may require some adjustment
- Gold Member
Re: pass or fail??
big_gordy wrote:here is the fails and advisorys
Rear Registration plate insecure (6.3.1b) requires resecuring
Front no beam pattern Headlamp aim aimed so that it dazzles other road users (1.**DANGEROUS** check the bulb is fitted correctly in the headlamp
Offside Front no beam pattern Headlamp aim aimed so that it dazzles other road users (1.**DANGEROUS** check the bulb is fitted correctly in the headlamp
Nearside Rear Brake hose ferrule excessively corroded (3.6.B.4e) replace to be safe
Offside Rear Brake hose ferrule excessively corroded (3.6.B.4e) replace to be safe
Front flexi pipe Exhaust has a major leak of exhaust gases (7.1.2a) will require replacing as there is not much you can do with a flexi pipe
Exhaust emissions carbon monoxide content after 2nd fast idle excessive (7.3.D.2b) down to hole in exhaust
Exhaust emissions Lambda reading after 2nd fast idle outside specified limits (7.3.D.2b) down to hole in exhaust
Advisory Notice issued work on these over time
this is what i would look at doing in my opion
this is what you should see on a beam pattern
http://img395.imageshack.us/img395/5043 ... 204pl5.jpg
- Club Member
Re: pass or fail??
is that beam patern with the same lights i have?
Re: pass or fail??
its the beam pattern you should be getting ...dont matter what make they are
Re: pass or fail??
the patern should be the same no matter what lights you have
Re: pass or fail??
well what i was told there is NO line at all its just a round pattern and that it wold be blinding ppl, im like wtf they passed last year
Re: pass or fail??
sounds like you need to wind them down
Re: pass or fail??
if the lights are to hight it wont give a clear pattern
Users browsing this forum: No registered users and 69 guests
