POWER STEERING FLUID
by big_gordy » Wed Sep 21, 2011 10:20 am
was woundering is there any bad or good power steering fluid ? ie like you get cheap nasty oil and then good oil?
if so what is a good brand for power steering fluid? :think:
Re: POWER STEERING FLUID
by v6 steve » Wed Sep 21, 2011 10:23 am
there all much the same, its not a race car so you dont need to worry about it to much just get what your local motor factor has on the shelf it will be fine
by big_gordy » Wed Sep 21, 2011 10:49 am
cheers for that steve !
by LE16 » Thu Oct 06, 2011 6:13 pm
Had to buy this like its going out of fasion from Halfords. They do a GM class fluid. Seems ok to me. On 4x4's though it an idea to use clear fluid if you can so that it makes it easier to see if its gone into the txb?
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
by v6 steve » Thu Oct 06, 2011 6:28 pm
how would brake fluid get into the txd ?
