Re: work has began
Just give it to Alan to sort out ,he just loves those spaghetti junctions
Dez
Re: work has began
Im no auto electrician but if u need a hand i can come up saturday to give you a hand or just to be on hand to rescusitate you incase you blow yourself up.
Dez
Re: work has began
How did the cableing get in that state in the first place?
Re: work has began
gawd thats some mess ............its even worse than my usual
Re: work has began
Dez wrote:Im no auto electrician but if u need a hand i can come up saturday to give you a hand or just to be on hand to rescusitate you incase you blow yourself up.
the "Drain" isnt here at the mo its up in my mates garage so i can work on it during the week
craigyboy wrote:How did the cableing get in that state in the first place?
the pic makes it look wores it was taken after i had a good pull at it
Re: work has began
I'm no good with electrics but would like to see some 1 blown up not seen a good injury for a long time
Re: My v6
its gone a long way since you started this thread and looks good
Re: The Drain
had a wee test fit of my new brakes all 353mm of them
they fit its close but no need for new alloys
Re: The Drain
v6 steve wrote:had a wee test fit of my new brakes all 353mm of them
Get them beauties bedded in, then get up to a ton on your private test track and stamp on the middle pedal
Tell us if it hurts.....
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
Re: work has began
got some work done on the mess
Re: The Drain
had a good wee day on the "Drain" got the brakes fittted all the polished bottels back on and the new seat sub frames weled and fitted , just got the dash to finish off before the 23rd of march
thanks again to ally
