Air bag light
Air bag light
Whilst putting the dash and steering wheel back on
tonight the airbag and management light have came
on,does anyone know how to put these off
help would be appreciated
Re: Air bag light
when my air bag light came on i had to have it pluged in to a laptop to turn it out
Re: Air bag light
we can turn your management light off not sure about the airbag one with our computer
Re: Air bag light
it does the airbag light as well
Re: Air bag light
What did you do, that required the Steering Wheel to be removed???
Re: Air bag light
Eddie i was putting in the brighter leds
cheers for that offer steve,i'll give you
a shout when i stop the overtime at the
weekends
weekends
Re: Air bag light
im 99% sure that it wont go out till its reset
Re: Air bag light
if you switched the ignition on with the airbag disconnected ..it will bring the light on until you get it reset ...our wee system does that
Re: Air bag light
Fraz wrote:if you switched the ignition on with the airbag disconnected ..it will bring the light on until you get it reset ...our wee system does that
thats what happened to me (on the passeger side airbag) i rebuilt the glove box but did not put the plug in correct and knocked it out so when i started it the light stayed on till i had it reset
Re: Air bag light
i made a bit of an a--se of that wee job
ive also not plugged the speedo cable
back in properly so back off tomorrow
again
again
Re: Air bag light
craigyboy wrote:i made a bit of an a--se of that wee job
ive also not plugged the speedo cable back in properly so back off tomorrow again
Did You fit any Coloured LED's in the Instrument Panel Warning Lights?
When I fitted the Dash LED's last week, I didn't unplug any of the Connections or remove the Steering Wheel...
I was told that the Steering Wheel should come off, but I'm glad I didn't listen...
Re: Air bag light
mine's not got a cable and i cant think of any of the others we have worked on having one
Re: Air bag light
Eddie i found it a bit easier to work on
with the wheel off
with the wheel off
Re: Air bag light
craigyboy wrote:Eddey... I found it a bit easier to work on, with the steering wheel off
I agree that it would make working on the Dash easier...
But in doing so, You also create more un-necessary work as well...
So I'm glad I opted NOT to remove it...
Anyway, I hope You get it all sorted out soon...
