Power chip 2.0 8v dont work good
by johnnybb » Fri Dec 30, 2011 7:41 am
Hi and good morning.I have a problem with one power chip.So I took it from one friend from his ECU.There it worked great.The model is the same as mine 95` motronic 1.5.I installed the chip in my ECU and start the engine.It starts normally and the rev. were 1100-1000 perfect,because with my chip they were 880-900.But as i push the pedal the change up ti 2000 but very slow.Then as I forced again there was detonation.BANG!!!And again.It is on LPG and gasoline.The chip is up to 132bhp I think and has some 4 degrees and +10% fuel after 3000rev...But in his car everythink was perfect!What can I do??
johnnybb
Re: Power chip 2.0 8v dont work good
by matty0785 » Fri Dec 30, 2011 12:19 pm
take it back out problem solved
by Mark1 » Fri Dec 30, 2011 12:27 pm
Take the battie off for 24 hours, the ECU needs to learn about the engine, put back and see how it goes. Had problems with the V6 after the rebuild until I let it go flat. 132bhp from just a chip seems a bit high to me but hay what do I know. :D
by D-Man » Sat Dec 31, 2011 2:03 am
Mark1 wrote:132bhp from just a chip seems a bit high to me
I would say that's unreal if we are talking about stock c20ne 8)
by big_gordy » Sat Dec 31, 2011 3:12 am
TAKE the LPG out!!!!! :whistle:
by johnnybb » Sat Dec 31, 2011 7:50 am
This f*****g LPG!I was thinking about that and I`ll do that! :think: Happy new year to everybody!
johnnybb
