Indicator stuck on
Indicator stuck on
by vec 160 » Sat Jan 21, 2012 9:33 pm
Opened the car earlier and set the alarm off. Now the driver side indicators are permanently on(not flashing).
Have tried disconnecting the battery but it has made no difference.
Does anyone have any idea what could be wrong,
Alan
Re: Indicator stuck on
by craigyboy » Sat Jan 21, 2012 11:57 pm
sounds like a stuck relay mate,open the fuse box under the steering
wheel and give them all a little tap with the ignition on.that might do
the trick.
by Fraz » Sun Jan 22, 2012 12:59 am
sounds more like your alarm is still trying to give some sort of warning ...might need to re set the alarm arm it then disarm it
by EddeyDancer » Sun Jan 22, 2012 1:07 am
Indicator Relay is probably the first thing I'd check...
Pull it out (as shown in photo) and inspect the 3 pins for any abnormal signs...
Get hold of another Relay to Test for Relay failure...
by Calibra_Mike » Sun Jan 22, 2012 12:45 pm
As above this would be my first point of call... pretty basic circuit really, if its not the relay then start looking at the alarm...
by vec 160 » Sun Jan 22, 2012 2:30 pm
Think I will have to look towards the alarm. Have relay out, indicator switch out and hazard warning switch out and the lights is still on
by v6 steve » Sun Jan 22, 2012 7:00 pm
Is all the idicator lights on or is it just one or one side it could be a bad connection at one of the plugs
by vec 160 » Sun Jan 22, 2012 8:30 pm
Eventually found that it was the alarm control unit. Took it out and everything was back to normal. Have put in another alarm control unit from the spare calibra i have(meant to be long term project) so that the alarm is working again
by v6 steve » Sun Jan 22, 2012 9:10 pm
:clap: well done fraz spot on :clap:
by Fraz » Sun Jan 22, 2012 9:50 pm
was more on about an after market alarm really
by v6 steve » Sun Jan 22, 2012 10:04 pm
Fraz wrote:was more on about an after market alarm really
You should have just taken the praise mate and said nothing lol
