Brake Lines
Brake Lines
just a quick note if you're ever replacing the HL line from the ABS unit you will find the fitting is a bigger thread than all the others
Phantom
Re: Brake Lines
i had that problam when i put the turbo in the se2 luckily the old was in good condition so i re used the original end
