Rust
Rust
had a look yesterday when I was doing my rear brakes for the rust issue that was picked up on during the MOT and could only see this, would I be right in guessing this must be it?
Re: Rust
does it look like it would be an MOT fail this is the only bit I could find that looked pretty nasy... and cheers for once again pointing out the obvious
Re: Rust
£100 to weld up... steep? bit close to the fuel tank for DIY IMO...
Re: Rust
true that... Ive got a mate that could do it but he's not a pro... maybe leave it to the pros on this one... I just need to learn to stop being so tight
Re: Rust
you should get 2 prices and compare them
QUOTE
v6 steve welding services
To cut out rust on chassis leg and weld in new metal
£1,000 000
thanks for letting us quote for this job and hope to be help to you in the future
Now does that make your £100 look cheaper
QUOTE
£1,000 000
