rear suspension
Re: rear suspension
craigyboy wrote:what type of shockers are recommended? The type on just mow
are jamex and p i springs
im sure if you ask most will say Billies (mods dont let Baz see this thread)
Re: rear suspension
The Bilsteins arrived today so thats another job
for me to get on with
Re: rear suspension
craigyboy wrote:The Bilsteins arrived today so thats another job
Which Bilsteins did you go for?...and did the rears come with new top mounts?
Re: rear suspension
BNE 1975, I got the mounts from vauxhall, vcp online
but had to get the metal inserts from a company online that
is in Ireland
is in Ireland
Re: rear suspension
craigyboy wrote:BNE 1975, I got the mounts from vauxhall, vcp online
is in Ireland
Thanks ....I asked as i couldnt remember if they came with mounts or not
How come you had to get the inserts from Ireland? I got mine from Autovaux.
Re: rear suspension
MadOnVaux! wrote:craigyboy wrote:BNE 1975, I got the mounts from vauxhall, vcp online
is in Ireland
It was the first ones i saw advertised mate
so i just got them
Are you refurbishing your rear suspension?
Re: rear suspension
craigyboy wrote:Are you refurbishing your rear suspension?
I'm not refurbishing it as such....I have a Rattley knocking coming from the back end, both sides but drivers side is worse....and no one can see what is causing it and no one seems to be able to diagnose it, so i keep having to ask things and i keep replacing things but it still knocks.
Oddly it only started when i had new (Bilstein B4) shock absorbers fitted which i doubt it would be them so i got new ARB bushes and subframe bushes and trailing arm bushes....got garage to fit them and still knocking, so got some new shock top mount bushes, fitted them, still knocking,
got some some metal inserts, fitted them, still knocking,
new rear anti roll bar links bought and lower bushes, still knocking.
and its nowt else either, as ive had all the interior out and it still knocks, its not the hatch or hatch struts....
Its driving me mad basically....short of buying new shocks, which i really dont want to do due to the expense, i really have no idea.
One lad said it could be the springs?....but springs surely wont cause knocking if they are not broken?
Re: rear suspension
MadOnVaux! wrote:I'm not refurbishing it as such....I have a Rattley knocking coming from the back end, both sides but drivers side is worse....and no one can see what is causing it and no one seems to be able to diagnose it, so i keep having to ask things and i keep replacing things but it still knocks.
i find turning up the button indicated below solves all knock and rattle sounds in and outside the car
Re: rear suspension
Check the springs mate to see if the coils have
been hitting off each other
Re: rear suspension
Allys Cally wrote:MadOnVaux! wrote:I'm not refurbishing it as such....I have a Rattley knocking coming from the back end, both sides but drivers side is worse....and no one can see what is causing it and no one seems to be able to diagnose it, so i keep having to ask things and i keep replacing things but it still knocks.
i find turning up the button indicated below solves all knock and rattle sounds in and outside the car![]()
LOL yeah someone has said that......most the time i dont have the stereo on, the sound of the engine/exhaust is far better
Re: rear suspension
craigyboy wrote:Check the springs mate to see if the coils have
Is that possible though? and how would i check that?
Re: rear suspension
The coils might be hitting each other and youll
be able to see the rust marks where the coating
has rubbed off.That could be causing the clunking
noise mate if youve tried everything else
Re: rear suspension
craigyboy wrote:The coils might be hitting each other and youll
Ok thanks, i thought they'd only hit each other if the car was bottoming out?....its an area to check though ta
My rear springs are in a pretty bad state though. i think they are originals...alot of the coating has flaked off them.
Re: rear suspension
If i was you mate i would get new springs then
theres nothing more annoying than hearing
clunking noises when you're driving
Re: rear suspension
craigyboy wrote:If i was you mate i would get new springs then
You've got me thinking this could be the cause actually.....if my garage has looked at it a couple of times and it's passed MOT's then nowt is surely loose at the back end to cause this clunking?, so if springs can cause it then it has to be the springs.
Just looked on ECP and i can get a pair of sachs springs for about £63 delivered......just wary of buying stuff now incase it still does it!!
and sorry for the semi hijack of your thread
