Gm vs Coscast
Gm vs Coscast
by KERR_SE9 » Sun May 06, 2012 3:38 pm
What are peoples thoughts on Gm vs coscast heads for xe/let engine, struggling to find a coscast and gm if repaired should be as good yes/no?
Re: Gm vs Coscast
by v6 steve » Sun May 06, 2012 3:42 pm
iv a coscast on the se2 but it was by chance iv had no problems with either but i'm not running silly BHP only 280 on the let
Re: Gm vs Coscast
by Allys Cally » Sun May 06, 2012 3:44 pm
coscast head with the rest of the engine, you pays your money you takes your chances
http://www.ebay.co.uk/itm/VAUXHALL-CORS ... 500wt_1287
Re: Gm vs Coscast
by KERR_SE9 » Sun May 06, 2012 4:33 pm
Seen that, end up £500+ with postage, stuff that for a head, picking up an Se2 tommorow with a spare Gm head for £200, Reckon I'll take Gm head off it and mot to sell on,rather than shell out sill money for a head
Re: Gm vs Coscast
by bennymac » Sun May 06, 2012 8:54 pm
i have run both without any bother although i did do the head sleeve before i used the gm head that I had.
Re: Gm vs Coscast
by Stupink » Sun May 06, 2012 9:48 pm
Never ran a costcast on a single one of mine. had the head on/off plenty of times, never had a problem. maybe i got lucky :)
Re: Gm vs Coscast
by Phantom » Tue May 08, 2012 5:16 pm
have had both, incidently the engine that is in the turbo now has a GM head and have had no problems
Phantom
Re: Gm vs Coscast
by stevo turbo » Tue May 08, 2012 7:33 pm
my let and xe are both on gm units, as said before i personally think they are overrated and over priced
Re: Gm vs Coscast
by GreyDJ » Tue May 22, 2012 6:53 pm
If an untouched GM head has lasted until 100k miles it will probably last the life of the car. If you disturb it it would pay to do the oilway sleeve mod, for peace of mind if nothing else, as it is so simple to do if the head is off the engine.
Performance wise there is nothing to choose although some say an early Coscast head from an XEJ, ex an Astra, has better airflow.
I can't see why Coscasts cost so much more than GM heads. The power of a myth I suppose.
I shouldn't grumble, both my LETs and my XEJ have them :)
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
