Fitted new aerial gasket today. Easy fix (pics)
Re: Fitted new aerial gasket today. Easy fix (pics)
by MadOnVaux! » Sun Jun 10, 2012 3:41 pm
MadOnVaux! wrote:Has anyone had any problems with these, such as water ingress after fitting?
Anyone?
by Robs-se » Mon Jun 11, 2012 7:47 pm
New base unit from Autovaux was only about £26 when i did mine end of last year
by MadOnVaux! » Tue Jun 12, 2012 9:30 pm
Robs-se wrote:New base unit from Autovaux was only about £26 when i did mine end of last year
That is a good price but if you dont need the base, and you know the gasket will go again in a couple of years it does seem pricey.
But then how long will this other gasket last?
by MadOnVaux! » Wed Jul 11, 2012 3:55 pm
Ive just bought one of these gaskets and should be fitting it soon :)
by Allys Cally » Wed Jul 11, 2012 4:08 pm
i bought one and fitted it the other week there when we were putting my car back together, so we'll see how long it lasts
by bluejuz » Wed Jul 11, 2012 10:56 pm
Mine still looks like new mate. And no water ingress even though mother nature is trying her best.
by Fraz » Wed Jul 11, 2012 11:17 pm
so did you buy the VW one or the one for the Vectra
http://www.ebay.co.uk/itm/Tigra-Vectra- ... 53e831e8ab
it says that is internal dimensions of 56 mm by 42 mm
and the VW one external dimensions of 60 mm by 43 mm
by bluejuz » Thu Jul 12, 2012 1:02 pm
I got the 60x43mm one. It's not necessarily a VW one really because it's the same size gasket the seller lists for a whole host of cars.
I just went with the biggest I could find at the time and with a little stretch seems to do the job.
by bluejuz » Thu Jul 12, 2012 1:10 pm
Fraz, just read your post again and I see what you mean.
One lists external diameter and one internal. So the vectra one could actually require less stretching to fit but it's hard to tell without having both gaskets. I just looked at the sizes and thought they were both internal diameters. Can't be much in it though!
by MadOnVaux! » Mon Nov 05, 2012 3:38 pm
Finally got round to fitting mine today, very tight fit even after having the gasket sat in red hot water for 5 mins...looks good and hopefully wont leak and will outlast the OE one.
by Robs-se » Tue Nov 06, 2012 1:04 am
That didn't take ypu long :D
by MadOnVaux! » Tue Nov 06, 2012 4:35 pm
Robs-se wrote:That didn't take you long :D
lol, erm yeah i know....combination of being busy and the weather being pretty crap on the days when i was actually free, and wanting to get other more essential jobs done beforehand.
by EddeyDancer » Tue Nov 06, 2012 9:31 pm
It's a gamble that will require time, in order to assess it's effectiveness...
I changed the whole base recently, as I found the Original Gasket itself, was not easy to seperate from it's mounting...
Some more photo's to assist the knowledge of such Topic...
