what you doing
what you doing
whats everyone up to today
im fixing shanes corsa for its mot doing an exhaust on Ally daughters car picking up my new turbo and playing with it, Alyy will be doing much the same but he'll not be getting to play with the turbo
Re: what you doing
Gony be spending this lovely day doing a bit
of welding on this se6
Re: what you doing
Working well I was I wrote fook on it and now driving home from Manchester
Re: what you doing
Well I got the car out of the garage hoping to get the boot cleared out ( chairs still in it from billing)
And noticed I had a fuel leak underneath, I presumed it was the tank but luckily it was the joint between the flexi and the solid pipe under the floor, so replaced clip with a stainless jubilee, that seems to of cured it for now, but pipes did look a bit grim so will get those replaced at some point.
I then thought while my hands stink of petrol i might as well do the other jobs that have been on the list for months now, which was fit the bosch red injectors to the polished fuel rail ive had for 2 years
after doing that I plumbed in the adjustable FPR.
Set the FPR to 3 bar vac off and blocked etc, it moaned and ***** a bit on start up, but after switching off and starting 3/4 times all seems good now.
Took it for a 5 mile drive and it seems smoother now tbh.
All seems ok so far.
Re: what you doing
been getting dirty
Re: what you doing
Looking good there mate
Re: what you doing
Fraz wrote:been getting dirty
What ya been doing to get dirty Fraz?
rich30mex wrote:Looking good there mate
Cheers Rich.
Re: what you doing
been under the car doing a wee bit of preventative maintenance
Re: what you doing
Very worthwhile job there Fraz, looks good.
Re: what you doing
Just been finishing off fitting the gearbox to te LE now time to relax
Re: what you doing
Been to work came home and lined up the clutch!!!!
Shaza
Shaza
My Old Turbo
My Old Turbo
- Secretary & Merchandise Support
Re: what you doing
20 bags of rubbish, 3 broken chairs, 1 bike and broken jack to the dump then jet washed the path down the side of the house. As for today I'm painting the side of the house
Toby comes back from the beakers with 1 front bumper, the plastic part that fits in front of the rear bumper on the Cally, just need to cut it to fit round the exhaust and odd screws and bits.
Re: what you doing
just going out to give the chevy a quick service oil, filters,plugs etc and investigate mystery oil leak near the auto box pipe work
Re: what you doing
Shaza trying to change her split hose!!
Re: what you doing
Fraz wrote:been under the car doing a wee bit of preventative maintenance
Good work going on there Fraz
