Fan and heater
in line crossovers
Could be a dodgy fan switch, only a few pounds to replace I think. It attaches to the lower back of the radiator on one side. I've never had one detatch itself (but you never know), but I have had them fail before - worth a look!
With the engine warm, does the temp gauge read at what you believe it should, or is it running too cold? Could be that you need a new thermostat.
HTH
Ben
PS - Welcome to the site
HTH
Ben
BenW
Initial compression test is a bit better..... I think.....
Yeah that would be ace
cornishcalibra
As I'm lazy, I just scanned a pic from the Haynes manual (of an 8v as it happens) rather than actually stepping out onto the driveway to take a proper pic
Haynes says:
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->If a faulty switch is suspected, the circuit to the fan motor can be tested by temporarily bridging the terminals in the switch wiring plug, and switching on the ignition. If the cooling fan now operates, the switch is faulty and should be renewed.<!--QuoteEnd--></div><!--QuoteEEnd-->
Haynes says:
BenW
v6 improvements
Ahh, hold on, I think I misunderstood the problem...you mean the blower fan! Sorry!
Wasn't there some kind of problem with the resistors in the motor that crops up occasionally? My car apparently had this, but the last owner fixed it so unfortunately I'm not sure of the details. The info must be here somewhere though...
BenW
cornishcalibra
<!--QuoteBegin-cornishcalibra+--><div class='quotetop'>(cornishcalibra)</div><div class='quotemain'><!--QuoteEBegin-->Hey does anyone know why the fan and heater would stop working on a calibra 8v. They just stoped but they will both work with direct power from the battery the fuses arent blown??????????[/b]<!--QuoteEnd--></div><!--QuoteEEnd-->
you aill probebly find that the switch has gone get the proper one from the main dealer not dear
paulv6
