polish removal
polish removal
by v6 steve » Fri Mar 15, 2013 9:56 pm
whats the best quickest easiest way to remove polish from my car ?
Re: polish removal
by Callyman » Fri Mar 15, 2013 9:59 pm
Ask them nicely to go back to poland? :lol:
Re: polish removal
by EddeyDancer » Fri Mar 15, 2013 10:01 pm
Rub it off with a rag...
Re: polish removal
by v6 steve » Fri Mar 15, 2013 10:04 pm
EddeyDancer wrote:Rub it off with a rag...
cant see how that will work, i want to strip all the polish off looks like the Tcut is coming out
Re: polish removal
by Callyman » Fri Mar 15, 2013 10:08 pm
A rubbing compound will do it Steve
T-Cut is quite abrasive mate.
Re: polish removal
by Allys Cally » Fri Mar 15, 2013 10:09 pm
t-cut would be the easiest way mate, either that or i can bring up my 9" grinder :twisted:
Re: polish removal
by v6 steve » Fri Mar 15, 2013 10:14 pm
i alway use water with t cut was hoping there was an easier way
Re: polish removal
by Fraz » Fri Mar 15, 2013 10:16 pm
wash it with washing up liquid instead of your normal washing soap ...or use your G101 at diluted in spray bottle at 100ml to 1 litre and go ove rthe whole car leave for a wee while then rinse off
beter still do both
Re: polish removal
by v6 steve » Fri Mar 15, 2013 10:17 pm
cheers uncle fraz i knew you would have a quick way
Re: polish removal
by Allys Cally » Fri Mar 15, 2013 10:36 pm
v6 steve wrote:cheers uncle fraz i knew you would have a quick way
so my 9" grinder and an abrasive pad no good then :(
Re: polish removal
by v6 steve » Fri Mar 15, 2013 11:05 pm
think ill give it a miss
Re: polish removal
by ytsrik » Sat Mar 16, 2013 9:38 am
Washing up liquid can dull the shine, I find luke warm water an a good microfiber cloth is good
Re: polish removal
by Fraz » Sat Mar 16, 2013 11:55 am
yes washng up liquid will dull the paint....as it will remove your wax and polish, which is what Steve is wanting to do :D
Re: polish removal
by mrvauxhall48755 » Sat Mar 16, 2013 6:28 pm
power wash it at local garage stay away from any stone chips peeling lacquer as water will get under and lift paint :naughty:
best presented ardrossan
Re: polish removal
by craigyboy » Sun Mar 17, 2013 1:38 am
what is the reason anyway? :think:
