Brake problem
Brake problem
I'm having problems with my breaks, keeps losing pressure. It's ok to start and then randomly it losses pressure and you have to pump them. They've been pressure bled and I can't find any leaks what so ever. No lose of fluid. PLEASE HELP!
Jesswest555
Re: Break problem
Seals gone in the master cylinder by the sounds of it
Re: Break problem
STEVA wrote:Seals gone in the master cylinder by the sounds of it
You will have to tempt him back out with a fish or 2
Re: Break problem
if its not that i could be the servo, the se2 had the same problem till i changed it
Re: Brake problem
Same symptoms as when my master cylinder went
Re: Brake problem
I need a calibra turbo 1996 Master Cylinder as I have same symptoms. I can't find one anywhere. Go on eBay and loads appear for calibras, but none for turbo?
Does anyone know where I can get one or would a saab 9-3 1998-2002 master cylinder fit? I was told it was the same?
Rob
Rob
Re: Brake problem
Rob have spoken to LMF or Autovaux as I would think one of them would be able to get the one you need.
Re: Brake problem
Thanks, spoken to Autovaux, they ate checking suppliers on Monday. It's a mission to find one lol. Not sure what seals as to many on eBay and would not know how to do so just want to get a new one or one from a breaking calibra that is fully working.
Saab 9-3 turbo 1998-2002 supposed to be the same.?
Re: Brake problem
arent the all the same apart from the v6 ? when i replaced the one on the se2 turbo i just took one out the shed dont know what i came off but it fixed the problem
Re: Brake problem
No I don't think they are all the same. The turbo is different. Anyone confirm?
Re: Brake problem
going by this there the same, cant see why they would be different
http://www.ebay.co.uk/itm/Vauxhall-Cali ... 19da5a494f
Re: Brake problem
So with 6 pot calipers on my le, is standard turbo master cylinder 23.88 bore ok, if not what's the upgrade?
Re: Brake problem
Anyone know if there is an upgrade master cylinder for 6 pot calipers?
