removing plastic side skirts
by Fraz » Wed Mar 20, 2013 6:51 pm
having never actully removed these ...how do they come off?? and they have never been off before so any clips that may have been broke/lost on other cars will still be on mine
have to take them off to get the damage painted
Re: removing plastic side skirts
by rich30mex » Wed Mar 20, 2013 8:10 pm
they are clipped on then pull them down and away from the car mine took some pulling to start with then thay came away easy once started. the second pieace has nilon m10 (6mm) nuts lots of them prity easy when you no how mate
by v6 steve » Wed Mar 20, 2013 9:19 pm
if you look from underneath you will see wee lugs once you see them it will come clear what you do with them then you can slide it off as rich said it may take some pulling to get it started then the other part is bolted with 100000's of plastic nuts, think the guy who designed them must have had a brother that supplied the nuts lol
by Robs-se » Thu Mar 21, 2013 8:34 pm
Screw driver into the rectangular slots at the back of the plastic stip and then just pop them off all the way along
by Phill » Thu Mar 21, 2013 8:57 pm
Fraz wrote:having never actully removed these ...how do they come off?? and they have never been off before so any clips that may have been broke/lost on other cars will still be on mine
Would you take some pictures and post them up Fraz.
