What a pain in the arse!!
by Matt Bartlett » Fri Mar 29, 2013 8:19 pm
Whilst removing the turbo today I sheared two of the manifold studs. Not a big deal really, drill a hole in each broken stud and extract it with an easy-out. Not that easy as it turned out!! Lets put it this way, I now have two broken easy-outs stuck in the engine block!! GRRR!!
Re: What a pain in the arse!!
by erkapic » Sun Mar 31, 2013 7:07 am
The broken studs are completely inside the engine block or sticking out a bit?
Sent from my GT-N7100 using Tapatalk 2
GOOD OLD CALIBRA
by erkapic » Sun Mar 31, 2013 7:15 am
I had the similar problem with 8mm studs which were sticking out of block about 10mm and successfully removed them using the tool like this
http://item.mobileweb.ebay.com/viewitem?itemId=271124958328
GOOD OLD CALIBRA
by Matt Bartlett » Sun Mar 31, 2013 10:06 am
Yes, sorry in the head. There's nothing at all sticking out unfortunately so had to go for the "drill down the centre" option. Thing is, the easy-outs were literally brand new!! Dont really wanna take the head off as the thought of timing the engine up on re-assembly worries me a bit. But if thats the only thing I can do.......
by Cali LE24 » Sun Mar 31, 2013 11:05 am
Try drilling most of the stud out. Say its a 10mm stud use a 9.5 mm dill bit then retap the threads.
Cali LE24
by Matt Bartlett » Tue Apr 02, 2013 10:24 am
Easy-out still stuck in the hole unfortunately. Has anybody heard of such a thing as a mobile machinist? If there is, perhaps I could get them to come to me rather than the head to them.
by Fraz » Tue Apr 02, 2013 3:05 pm
doubt it as the tool required to get an Easy out ...out, are going to mean its going to have to be clamped and then usually they burn it out and then re drill and helicoil it, so cant really do that in place
by stevo turbo » Thu Apr 04, 2013 6:01 pm
if you can get the easy out bit out from the studs try and hammer in a torqx bit and if possible get some heat on it and just be patient in getting it out, plenty of wd 40 and just work it in and out.
by bodgetastic » Thu Apr 04, 2013 11:31 pm
Give a friendly mechanic a call, they'll probably get it out in minutes
by v6 steve » Fri Apr 05, 2013 10:23 pm
bodgetastic wrote:Give a friendly mechanic a call, they'll probably get it out in minutes
Friendly mechanic :think: youll be lucky all the mechanic i know are grumpy pain in the bums
by stevo turbo » Sat Apr 06, 2013 12:27 am
Screw you!
by v6 steve » Sat Apr 06, 2013 12:39 am
stevo turbo wrote:Screw you!
i rest my case :snooty:
by Chavtastic » Sun Apr 07, 2013 12:48 pm
Get the easy-out off, then soak it in WD40 a few times a day for a couple of days
Then after heating up the head around the stud (hobby torch is good for this) use two nuts locked together to unwind it.
Works for me almost every time.
by matty0785 » Sun Apr 07, 2013 1:33 pm
as chav says or if it doesnt work drill into the middle of the stud and hammer a torqx bit in and un screw it
by Matt Bartlett » Tue Jun 04, 2013 7:33 pm
Got my head back at the weekend, minus the easy-outs! Cost the grand sum of £15!! Mates dad owns his own machining business and did it in his spare time. That's what you call lucky lol!! Gasket sets, timing belt kit and a few other bits ordered so should be busy for a little while...
