The End
The End
Well thats the end of my show season The LE's big ends have gone looks like last weeks oil pump failure did for them, so its needing a full engine rebuild the plan was to do the big turbo/engine build over the winter so not much point doing a engine build on an engine thats getting pulled out just for the shows, so there will be no Davies calibras this year, it will be the big oil burner for Billing this year
Re: The End
drop the sump and remove the rod caps check the shells and check the crank if the crank hasnt been scored get yourself a new set of shells and give it a bash
invest in a plastigauge to check tolerances before ordering new shells as you made need to get slightly oversize ones
Re: The End
As above, hopefully its just the shells and will be fine for PVS, worth giving it a go even your going to be stripping it down anyway
Re: The End
Your not giving up that easy are u
Re: The End
if only it was that easy !!
if the shells are gone theres nothing to say that the pistons or the rings or even the turbo didnt sustain damage too im not going to throw good money at it when there always was a bigger plan for the LE
Re: The End
you wont know till you check
for the sake of checking and 100 quids worth of bits to make this years shows
if its buggered its buggered but you wont know until you check
