Brembo brakes
Brembo brakes
Hi guys and girls, just landed myself a set of fiat coupe 20v turbo brembo calipers, just wondering if i could use the standard fiat discs with these on my 4 stud calibra? if not then any ideas what discs i could use? Thanks
g113wrx
Re: Brembo brakes
pcd is the same so should work
Re: Brembo brakes
matty0785 wrote:pcd is the same so should work
cheers bud, i was told the discs are a different offset?
g113wrx
Re: Brembo brakes
No reason to use fiat discs since you still need a custom adapter for fiat calipers. Better to get the right adapter to fit fiat calipers to vauxhall discs.
Re: Brembo brakes
D-Man wrote:No reason to use fiat discs since you still need a custom adapter for fiat calipers. Better to get the right adapter to fit fiat calipers to vauxhall discs.
But isn't the problem, solved by using Fiat or Renault discs, finding big enough 4 stud Vauxhall discs?
Surely its easier to change discs than callipers?
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
Re: Brembo brakes
ill be having some brackets made to fit the brembos just unsure on what discs, if the fiat discs offset is ok then shoud be fine just thought id ask so i dont get the wrong discs. thanks for the help though guys.
g113wrx
Re: Brembo brakes
i got a set a few years a go did a mock up youll need 18" alloys to fit round them i sold them on and went DB9 ones instead
Re: Brembo brakes
v6 steve wrote:i got a set a few years a go did a mock up youll need 18" alloys to fit round them i sold them on and went DB9 ones instead
Fascinating, that means the Fiat callipers must stick out a lot more than the GM ones.
Re: Brembo brakes
Thought id need at least 16s not 18s, the fiat they came of has 17s i think?
g113wrx
Re: Brembo brakes
g113wrx wrote:v6 steve wrote:i got a set a few years a go did a mock up youll need 18" alloys to fit round them i sold them on and went DB9 ones instead
and by the time you make up a mounting bracket it will pull it out further
Users browsing this forum: Google [Bot] and 2 guests
