Rear bumper mounts
Rear bumper mounts
by Phill » Fri Jul 19, 2013 7:11 pm
I removed the rear bumper on the ecotech today and found the 4 bumper mounts are fooked. Can you still get new ones ? and from who ?. Thanks.
there wasn't much left of the 2 at the back of the bumper to get a picture.
Re: Rear bumper mounts
by v6 steve » Fri Jul 19, 2013 7:53 pm
no you cant get them any more but its not as if they would be to hard to make, the drain dosnt have any and iv not had any problems with out them
by Allys Cally » Fri Jul 19, 2013 8:06 pm
v6 steve wrote:no you cant get them any more but its not as if they would be to hard to make, the drain dosnt have any and iv not had any problems with out them
i dont have any on the se9 either
by Phill » Fri Jul 19, 2013 8:18 pm
So is it just the screws at the arch that will keep them on ? I plan to put it on the V6 as it's in better condition til i can get a respray. I'm going to be removing the front bumper and swap that to. What should i expect when taking the front off ?. Any advice on removal and refit would be much appreciated. :)
by v6 steve » Fri Jul 19, 2013 8:22 pm
there is 2 lugs that fit just under the number plate and 2 studs under the bumper too
by STEVA » Fri Jul 19, 2013 8:25 pm
I can ask my friendly vx dealer next week if you want as they will do a search for me!!
by Phill » Fri Jul 19, 2013 8:38 pm
v6 steve wrote:there is 2 lugs that fit just under the number plate and 2 studs under the bumper too
The 2 plastic studs under the bumper are there but the brackets crumpled when i touched them. I think i will need to make 2 brackets for the studs.
by Phill » Fri Jul 19, 2013 8:40 pm
STEVA wrote:I can ask my friendly vx dealer next week if you want as they will do a search for me!!
If you could check the 4 for me that would be grate Steva.
by STEVA » Fri Jul 19, 2013 8:43 pm
No bother mate will do! :)
by craigyboy » Fri Jul 19, 2013 9:07 pm
Alright phil,I made mine out of 25mm flat bar and
just gave them a coat of Hamerite,as I knew I would
struggle to get new ones
by James_Mould » Fri Jul 19, 2013 9:18 pm
Have you tried Autovaux to see if they have any left? I managed to get a set from them last year.
by Phill » Fri Jul 19, 2013 9:25 pm
James_Mould wrote:Have you tried Autovaux to see if they have any left? I managed to get a set from them last year.
I will give them a call tomorrow James, Thanks.
craigyboy wrote:Alright phil,I made mine out of 25mm flat bar and
Looks like you may have just talked yourself in to a job mate :lol:
by EddeyDancer » Wed Oct 23, 2013 4:24 pm
I can supply these 'Rear bumper Brackets' if anyone wants Genuine Parts in Top Condition...
