ridiculous dealer parts prices
needed a new front crossmember for the calibra, MOT fail for hole... price from vauxhall dealer ?
£890 !
Sorted.. I got an ok cavalier one £20 from ebay.. and it just unbolts, and bolts on.. rust allowing.. but WTF is it with prices like that ?
£890 !
Re: ridiculous dealer parts prices
be interesting to see if the equivalent part for a mercedes coupe is cheaper
doh ! of course..stupid.. they probably ran out of stock in germany and had to get a small batch re-fabricated from an independent maker.
Surprised Vauxhall could find one. They usually get passed onto Greenparts or similar after 10 years.
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
there are about 3 bolt on parts to go to just one side of the front chassis, so at vauxhall prices having a front end shunt just for parts alone.. would be about £2-4000
With that number in stock and a reducing numbers of cars they fit, you would think they would cut the price to sell them rather than write them off in a few years.
No wonder insurance companies write cars off.
It's all part of the continuing conspiracy to get older cars off the road
Teejay wrote:It's all part of the continuing conspiracy to get older cars off the road
Never
Do you not know anyone with a welder?
callyman wrote:Do you not know anyone with a welder?
got another one of ebay anyway..more peace of mind the fronts not going to twist off..
[quote="Teejay"]It's all part of the continuing conspiracy to get older cars off the road
Load of nonsense. The amount of carbon to produce a new electric car is masses more than running an old oil burner on low mileage.
Does an electric car gave to be made of carbon then?
callyman wrote:Does an electric car gave to be made of carbon then?
of course not..
amount of Co2 and waste to produce an electric car in the entire processhere comes the science bit
http://www.theguardian.com/environment/ ... nt-new-car
The carbon footprint of a new car:
6 tonnes CO2e: Citroen C1, basic spec
17 tonnes CO2e: Ford Mondeo, medium spec
35 tonnes CO2e: Land Rover Discovery, top of the range
The carbon footprint of making a car is immensely complex. Ores have to be dug out of the ground and the metals extracted. These have to be turned into parts. Other components have to be brought together: rubber tyres, plastic dashboards, paint, and so on. All of this involves transporting things around the world. The whole lot then has to be assembled, and every stage in the process requires energy. The companies that make cars have offices and other infrastructure with their own carbon footprints, which we need to somehow allocate proportionately to the cars that are made.
In other words, even more than with most items, the manufacture of a car causes ripples that extend throughout the economy. To give just one simple example among millions, the assembly plant uses phones and they in turn had to be manufactured, along with the phone lines that transmit the calls. The ripples go on and on for ever. Attempts to capture all these stages by adding them up individually are doomed from the outset to result in an underestimate, because the task is just too big.
The best we can do is use so-called input-output analysis to break up the known total emissions of the world or a country into different industries and sectors, in the process taking account of how each industry consumes the goods and services of all the others. If we do this, and then divide by the total emissions of the auto industry by the total amount of money spent on new cars, we reach a footprint of 720kg CO2e per £1000 spent.
This is only a guideline figure, of course, as some cars may be more efficiently produced than others of the same price. But it's a reasonable ballpark estimate, and it suggests that cars have much bigger footprints than is traditionally believed. Producing a medium-sized new car costing £24,000 may generate more than 17 tonnes of CO2e – almost as much as three years' worth of gas and electricity in the typical UK home.
Interestingly, the input-outpout analysis suggests that the gas and electricity used by the auto industry itself, including all the component manufacturers as well as the assembly plant, accounts for less than 12% of the total. The rest is spread across everything from metal extraction (33%), rubber manufacture (3%) and the manufacture of tools and machines (5%) through to business travel and stationary for car company employees.
The upshot is that – despite common claims to contrary – the embodied emissions of a car typically rival the exhaust pipe emissions over its entire lifetime. Indeed, for each mile driven, the emissions from the manufacture of a top-of-the-range Land Rover Discovery that ends up being scrapped after 100,000 miles may be as much as four times higher than the tailpipe emissions of a Citroen C1.
With this in mind, unless you do very high mileage or have a real gas-guzzler, it generally makes sense to keep your old car for as long as it is reliable – and to look after it carefully to extend its life as long as possible. If you make a car last to 200,000 miles rather than 100,000, then the emissions for each mile the car does in its lifetime may drop by as much as 50%, as a result of getting more distance out of the initial manufacturing emissions.
When you do eventually replace your car, it obviouslty makes sense to do so with a light, simple and fuel-efficient model: that way you'll be limiting both the manufacturing and the exhaust-pipe emissions. But before you buy, look into car clubs, especially if you live in a city centre: you may save lots of money as well as reducing the number of cars that need to be produced.
Of course, the exact benefits of new versus old cars, diesel versus hybrids, car clubs versus owning, and so on, are different for each person. To find out the greenest choice for you, check out the new interactive greener car guide at Startuk.org.
So the summary of that is it turns out to be more eco friendly to hang on to our calibras for the forseeable future. few of us are running anywhere new car mileage on them anyway.
