Some pics from our mini meet
Re: Some pics from our mini meet
by Chavtastic » Tue Sep 17, 2013 8:25 am
4x4 is all fitted except the propshaft as I just wanted to get that painted up and have the brackets powdercoated. I'll get it done before winter.
by trev150 » Tue Sep 17, 2013 3:41 pm
Give us a shout on your next meet as i'm only down the road.
Cheers,
by v6 steve » Tue Sep 17, 2013 8:42 pm
why have a 3.2 and put LPG on it ? :snooty:
what system are you going to use ? the last v6 i say with LPG it was making the engine run low on power when lpg wasnt on due to the system blocking air intake if its about mpg why not stick a bmw oil burner in
by Chavtastic » Wed Sep 18, 2013 12:43 pm
Will do Trev!
v6 steve wrote:why have a 3.2 and put LPG on it ? :snooty:
3.2 V6 because it's the most powerful, smoothest engine that is a direct fit to a Calibra, and the most reliable after the C20NE
LPG because it improves the throttle response, burns cleaner (oil stays golden!) and might even make more power.
It's also half the price of petrol.
v6 steve wrote:what system are you going to use ? the last v6 i say with LPG it was making the engine run low on power when lpg wasnt on due to the system blocking air intake if its about mpg why not stick a bmw oil burner in
That was either a faulty system or badly installed / mapped. Myself and two good mates already run LPG Vauxhall engines (one is a V6) and they run better on LPG, as you'd expect.
I've bought the best system you can get OMVL Dream 8)
I don't want a BMW engine.
by Teejay » Wed Sep 18, 2013 2:47 pm
BMW engines make your indicators stop working!
by zethos » Wed Sep 18, 2013 6:25 pm
really nice pics
by v6 steve » Wed Sep 18, 2013 6:55 pm
I don't want a BMW engine.[/quote]
not sure what the system was called but it was like a cooker gas burner stuck in the middle of the air intake pipe, ill be interested to see some figures once its in
by Teejay » Thu Sep 19, 2013 7:22 am
Welcome along Zethos, good to see you here!
