My W.I.P
Re: My W.I.P
craigyboy wrote:What have you got planned next for the car mate?
Paying his membership before Steve takes the parcel shelf back
Re: My W.I.P
If anyone wants that parcel shelf I'll happily swap for a good condition standard one that's not saggy
It'll probably just be new paint that's next craigy . Body shop at the start of April
Praise the Lowered !
Re: My W.I.P
Ill swap you for a clean standard shelf and its not saggy!
Re: My W.I.P
KERR , sorry buddy , craigyboy said he'll fix it with some mdf so it looks like it's staying .
Re: My W.I.P
I noticed a while ago there was a little water in the spare wheel well . I stripped out the boot & took off the plastic back panel to find that BOTH sunroof drains had came out their sockets ! I put them back in & cable tied them so they'll not budge .
Thankfully it's still not too bad looking in there seeing as it's out in all weathers
Re: My W.I.P
If you look closely you can see the amount of water that's run out the soundproofing while the carpet was over the fence....
Re: My W.I.P
Well done John
,that seems to be a common problem with the Calibras
Re: My W.I.P
i cant believe that vauxhall never made the pipe 50mm longer then it wouldnt fall out, cheap skates
Re: My W.I.P
Cheers guys . Steve I totally agree ! The drains actually looked as if they have been shaped to go over the top of the bulbs in the rear light cluster . Anyone not aware how easily these tubes come out could pull it out & not even realise ! I put the cable ties on mines as when I was putting the carpet back into position the corner of the carpet actually caught it & pulled it out again !!! Hopefully now it'll be solid & the car won't mist up as bad now.... Time will tell
Re: My W.I.P
Might be a good idea to super glue them in or silicone
them in mate.
them in mate.
Re: My W.I.P
Aye deffo Craig ! Am gonny silicone the wee water drain on the sides of the hatch too as when a took the carpet off the sides there was a damp bit directly underneath where they were . Looks like they've been weeping a wee bit . I'll show you next time I'm up .leaky vauxhalls
Pah !
Re: My W.I.P
Dropped the auld girl off at body shop last week to get the bottom half on both sides sprayed along with the underside of the doors . Had the bit behind the number plate painted too & the whole car machine polished . Really happy with how it turned out
Once the paint hardens & I can was it I'll post up some new pics
Re: My W.I.P
Yep , he done a smashing job
