calibra 16v cool line green.
Re: calibra 16v cool line green.
by Philippe » Wed Mar 12, 2014 4:59 am
voilà les photos avec la banquette AR
les sièges et panneaux portes AV
a venir bientôt :
nouvelle embase et joint d'antenne neuf
( interieur ) montant pare brise, supports plage AR et montants ceintures noirs
platine de chauffage complete avec cable a changer ( j'en ai trouvé une )
et la petite vidéo .
http://www.youtube.com/watch?v=Z5uXx076FMI
bye
-----> My calibra 16v
-----> My site ------> CALIBRA-ECOTEC
by rich30mex » Wed Mar 12, 2014 9:56 am
Looking good mate
Events Coordinator
Events Coordinator
by craigyboy » Wed Mar 12, 2014 7:18 pm
Excellent mate,plenty of good pictures there :clap:
by EddeyDancer » Thu Mar 13, 2014 2:29 am
Very nice, but would look so much better with wheels similar to the dark blue Calibra
by Philippe » Thu Mar 13, 2014 7:00 am
no i love full stock :P
bye
by DanSE4 » Thu Mar 13, 2014 1:15 pm
Philippe wrote:no i love full stock :P
Quite right too!
Excellent example of an original Calibra you have there, best thing you can do is keep it that way. :)
Calibra SE4 3.2 V6 + F28
A Couple of German Cars!
by Philippe » Thu Mar 13, 2014 8:36 pm
yes
changed my seal and blade antenna AR reattached.
I managed to put on the new base my cable washer fluid ..
Here photos
headliner removed
antenne enlevé et debranchée
joint usé et neuf
tuyau lave glace et buse enlevé sur ancienne embase
tuyau et buse lave glace rajouté a la nouvelle embase
et voilà antenne posée et rebranchée.
ciel de toit avec lame recollée
ciel de toit noir perso, fait par l'ancien proprio,
this is cool, after I put windshield banner, belts amounts
and supports beach black AR like that, my whole interior is black :)
next step, installing the oil separator :)
by Philippe » Fri Mar 14, 2014 8:28 am
by EddeyDancer » Fri Mar 14, 2014 11:15 am
I have 'Stock Stereo' if you want it...
by Philippe » Fri Mar 14, 2014 11:23 am
which ??
by Philippe » Wed Mar 19, 2014 7:01 pm
ca y est, j'ai posé mon séparateur d'huile, tres content :)
et voilà ma chienne,
BAF poil long. LOF confirmée. alarme 5*
by Philippe » Fri Jun 13, 2014 6:30 pm
voilà, fini !!
quand je l'ai eu.
produits utilisés. ( paille de fer triple 0 et du ouator.
pendant les evolutions
et fini... ca brille ;)
photos montés.
avec du contraste
by craigyboy » Fri Jun 13, 2014 7:09 pm
Lovely looking car mate and you did an excellent
job of that heat shield :clap: :clap:
by Philippe » Sat Jun 14, 2014 5:12 am
voilà les pièces recues...
photos
plaquettes AR BREMBO
capteur vilebrequin siemens
ca y est, j'ai recu mes 2 triangles MAPCO neufs
avec les silent bloc et rotules
+ le capteur AAC siemens modifié avec le cable..
photos
Triangles before, modified sensor AAC siemens.
+ Sensor brace siemens, plaques back changed.
Cleaning of candles and a changed radiator hose of air.
Brake has hand back re-tautened and balanced.
Change of the joint of safe(chest) and addition of masks(hiding places) screw tailboard and steering wheel makes.
It's perfect, the driving clairvoyant(light) does not ignite and now I have none defects.,
voilà les photos, voiture dans le garage.
plaquettes AR
triangles AV neufs posés.
changement des capteurs.
on a changé cette durite, elle était completement HS.
by Philippe » Thu Aug 07, 2014 9:16 am
hello there,
since I exchanged my leather interior that was wearing against an internal calibration team.
I modified the bottom of the panel and put down the leather panels ...
I'm a attentte compreseur aircon, a headliner like new and soon, I'll change the dashboard to add and connect a passenger airbag
since I did the timing belt + rollers and water pump
drain filters + + linkage adjustment.
Place pictures
intérieur....
extérieur....
centralization kit
dashboard and passenger airbag
