Simple list of parts to use a f28..
As i cant seem to sell my calibra ive decided to make it 6 speed,can any one give me a simple list of parts that i need,thanks,some people say i need a spacer?? Can i just use a redtop flywheel or do i need a let 1?
Re: Simple list of parts to use a f28..
Which engine have you got?
V6 dont have the cash to buy a turbo,
Plus you will need an F28.
I might have one for sale
It sounds very complicated just for 6 speed,think ill just use a f20 then as u dont need no spacers then,thanks for the help
Dam i cant put up with my long ratio box and that monster fly wheel,
the list makes it sound hard and a lot of work its not that bad or hard just get on with it
My 3.0 Cally has an F28 in it and it transforms the car
My 3.2 has the F25 in it and they are night and day
Thanks for the good advice ill have a look for a f28 box now,will it b any better on fuel as ive put £110 in it and only done 480 miles thanks
Following a call from the brethren north of the border, you will also need a six speed gear lever because the reverse is in a different position on the F28 to the F25 and you have the safety collar lockout.
Not unless you ditch the lead lined driving boots.....
http://en.wikipedia.org/wiki/Getrag_F28/6_transmission
1st gear ratio: 3.57:1
2nd gear ratio: 2.16:1
3rd gear ratio: 1.45:1
4th gear ratio: 1.10:1
5th gear ratio: 0.89:1
6th gear ratio: 0.74:1
Reverse gear ratio: 3.23:1
Final drive ratio: 3.72:1 (front)
http://en.wikipedia.org/wiki/F25_manual_transmission
1st gear ratio 3.38:1
2nd gear ratio 1.76:1
3rd gear ratio 1.12:1
4th gear ratio 0.89:1
5th gear ratio 0.77:1
Reverse gear ratio 3.17:1
differential ratio 3.82:1 or 4.05:1
So the :1 is output speed of the gearbox, X.XX is gearbox input speed or engine rpm.
6th gear on the F28 is as close as dammit to 5th on the F25 so high speed cruising won't see ant difference. You might end up using more because of the shorter ratios of the F28 through the gears.
But shorter ratios equals faster acceleration. So looking at the above the F28 will be faster through the gears, unless you fluff a gear change
From my own unscientific testing F25 3rd gear tops out at 115, F28 3rd tops out at 88........
Then it all goes blurry and I wake up in 1963
rustyarches wrote:will it b any better on fuel as ive put £110 in it and only done 480 miles thanks
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
Get it fixed and get it to Billing
