spongy brakes
Re: spongy brakes
by ytsrik » Sat Aug 03, 2013 7:30 pm
v6 steve wrote:i would say youv still got air in them
Thinkin your right steve maybee another go or like Craig says a bleed kit as Tracy's right leg still aching!!
Re: spongy brakes
by Callyman » Sat Aug 03, 2013 9:32 pm
I reckon i will use my kit to push a complete flush through, then do half a dozen pumps the manual way.
Re: spongy brakes
by Robs-se » Sat Aug 03, 2013 11:51 pm
Could be a leaky resevoir/master cylinder
Re: spongy brakes
by Topbuzz » Sat May 17, 2014 5:11 pm
Follow this, never failed me
http://www.stoptech.com/technical-support/technical-white-papers/bleeding-brakes
I've got one of those one-man bleeding kits but it never works. In fact when you connect it up to the spare tyre there is usually too much pressure in the tyre so it forces brake fluid out from the brake reservoir :(
If your paranoid that air is still in the ABS unit, follow this
http://www.stoptech.com/technical-support/technical-white-papers/bleeding-abs-brake-systems
Alan Knight (Topbuzz)
W: www.topbuzz.co.uk
E: webmaster@topbuzz.co.uk
Re: spongy brakes
by v6 steve » Sat May 17, 2014 7:21 pm
im sure he fixed it or crashed and never came back on it was 9 months ago lol
Re: spongy brakes
by KERR_SE9 » Sat May 17, 2014 9:37 pm
Pretty sure it's in my garage
