Problems with my heater
by vauxhallben » Wed Feb 18, 2015 4:55 pm
Hi guys having a issue with heaters, when it's cold outside the heat coming out the vents is luke warm if that, that's with the control on full and the fans turned on full, any suggestions? It's ok when it's a little warmer outside
Thanks
Re: Problems with my heater
by vauxhallben » Wed Feb 18, 2015 5:09 pm
The thermostat works I believe, it's sits in between 90-100, I could try flushing heater matrix, never done it before tho
by vauxhallben » Wed Feb 18, 2015 5:26 pm
Ok I will try that first, thank you for your advice
by Allys Cally » Wed Feb 18, 2015 7:00 pm
Check the pollen filter under the scuttle panel, mine was soaking wet and full of crap. Took it out and cleaned the elephants truck out and that cured it
by vauxhallben » Wed Feb 18, 2015 7:10 pm
Ok I will check that as well thank you
by KERR_SE9 » Wed Feb 18, 2015 10:26 pm
2nd for the matrix, flush the pipes in both directions and loads of crap will come out!
by vauxhallben » Thu Feb 19, 2015 12:28 am
Ok I will take a look on Friday
