Rear brake backings rusted through
Hi Guys. Got the old problem of the handbrake shoe pins grinding the hub because the rear brake backing is rusted through on my 94 turbo. Did anyone find a solution for this? Does anyone know where I can find replacements? I've looked everywhere. Also, how would I go about fixing this problem and keeping the old girl on the road?
Thanks for any advice in advance- it's much appreciated.
Re: Rear brake backings rusted through
I got new ones from Autovaux two years ago,you should try
them,hopefully they still have some.Before that I put penny
washers on the back to hold the pins as a temporary fix.
Spoke to them yesterday, they dont have any, might be able to find a passenger side, but driver's side no chance.
Cheers guys. Thanks for the call Callyman. Yup, I'll washer them up and see if they hold.
Thanks again.
Thanks again.
Hi Pedro, I used some quick steel to bond the largest washers i could get to the backplate, I also put the 2 springs on the hand brake shoes at the back of the shoes. A very old mechanic frend told me to do that as the springs are under tension, they try to pull the shoes away from the backplate resulting in the pins being ripped from the rusty backplate. By reversing the springs you are making the springs pull the shoes to the backplate and taking the pressure off the pins. I never had a problem with the pins after i did this. I hope this helps
Yup, good idea phill- I'll try the spring trick and see if it works. Thanks guys.
I did a how to fix them......its on cc.com tho....
sealeysonic wrote:I did a how to fix them......its on cc.com tho....
Not much effing use here then.
Post it here too.
Calibra SE4 3.2 V6 + F28
A Couple of German Cars!
Lol i should do.....i dont come on here much as im not a paid member and feel like a free loader lol
Its not the best way...by far but it works...
Why did you make one of the hub face holes bigger?
To get the drill extention through on the left side.
