My cally
Re: My cally
Great progress..mate.
Re: My cally
Not yet steve, still layering it up. Tried it in and its quite the snug fit
Re: My cally
i made some for the se2 and was thinking about doing one for the LE would be good to see your fit before i start
Re: My cally
I'll pop it in the hole tonight after work and let you know.
Re: My cally
HOT-ROD wrote:I'll pop it in the hole tonight after work and let you know.
I bet you will lol
Re: My cally
rich30mex wrote:HOT-ROD wrote:I'll pop it in the hole tonight after work and let you know.
I bet you will lol
Re: My cally
Re: My cally
Should look good when its finished mate
Re: My cally
They look sound pal well done mate
Re: My cally
The box is all done apart from the trimming. While I had a spare 10 mins i decided to strip most of the ice out of the "hotrod" because I've had a complete change of plans for that. I now have all this and a little more to squeeze in the cally while trying to keep as much boot space as possible since its still being used as my daily.
The other problem I have is I need to keep it discreet because the car lives its life out in the street while the "hotrod" stays tucked up in the mancave!
Re: My cally
Been a while since I been on but I did manage to get the box finished and trimmed.
Unfortunately I didn't have as much grey carpet as I thought but the black will do for now. All I have to do is build the amp rack. This took a little more work than I originally planned.
(Nice picture of my hand!
That's a nice little subtle install fitted just in time for my trusty head unit of 15+ years to break so I've tracked down a temporary stand in.
Unfortunately while fitting the amp I managed to break the rear seat belt. Managed to track down a replacement (cheers Steve!) And got a pair of new gators too just to freshen up the trim a little.
Hasn't been a bad month for the motor but I think the brakes might be the next job in hand as I'm getting a lot of vibration through the pedal under heavy braking.
Re: My cally
Looks good
