Standard Lights - Halo Rings
I'm finally gonna do it! I have myself a set of clear lenses so just need to order the halo's now!
30 mins of searching and I give up! Can someone please head me in the right direction please?
Re: Standard Lights - Halo Rings
Where did you get the clear lenses from bud?
Sorry, from a clear set of Sonar Angel eyes.
The proper bright fluorescent ones.
that's the type. Please any one who has done this mod give me the size rings o use?
They look better than the ones i had a few years back.....Theres a guide somewhere on modding the "sonar" lenses so there water tight.
I think it's 60 mm and 70mm
Sent from my SM-G925F using Tapatalk
Thanks all
Received the 60mm rings from one supplier today! One ring broken
The fleabay led rings look better..as the neon ones are glass...i had them on my old 8v one cracked a few months after fitting..mabe due to thermal shock...from the halogen bulbs or early starts in winter.
If you get led ones you could add SMD chips to brighten them up more.
This is true mate...the sonar angel eyes were crap.
Well I've finally got all the bits, just need to find the time!!!
The CFL type seemed way too fragile so going with the LED type, even brighter
Where do I find the "guides" on this site?
Great!
Using standard super glue the rings won't stick to the shiny metal! Guess I'm gonna need proper Metal super glue?
