Standard Lights - Halo Rings
Re: Standard Lights - Halo Rings
by sealeysonic » Thu Sep 03, 2015 5:51 am
The fleabay led rings look better..as the neon ones are glass...i had them on my old 8v one cracked a few months after fitting..mabe due to thermal shock...from the halogen bulbs or early starts in winter.
If you get led ones you could add SMD chips to brighten them up more.
by sealeysonic » Thu Sep 03, 2015 8:09 am
This is true mate...the sonar angel eyes were crap.
by RedCalibra33 » Sat Sep 12, 2015 9:37 am
Well I've finally got all the bits, just need to find the time!!!
by RedCalibra33 » Sun Oct 25, 2015 10:00 pm
The CFL type seemed way too fragile so going with the LED type, even brighter :D
by RedCalibra33 » Thu Oct 29, 2015 8:32 pm
Where do I find the "guides" on this site?
by RedCalibra33 » Thu Oct 29, 2015 10:56 pm
Great! :naughty:
Using standard super glue the rings won't stick to the shiny metal! Guess I'm gonna need proper Metal super glue?
by John appleby » Tue Nov 03, 2015 9:32 pm
We're did you buy these from they look good
Sent from my SM-G928F using Tapatalk
by Callyman » Wed Nov 04, 2015 9:00 am
RedCalibra33 wrote:Great! :naughty:
Use clear silicone. :D
by RedCalibra33 » Thu Nov 05, 2015 9:50 am
Buying clear silicone today to seal the lens so will run a line around the rings too!
They certainly are bright, I've ended up super gluing a ring of cardboard to the back of the ring, then that to the headlight, which isn't metal after all! Magnet doesn't stick to it but meter reads 0 ohms across it!?
I've used 60 and 70mm.
http://www.ebay.co.uk/itm/360983290802? ... EBIDX%3AIT
by RedCalibra33 » Tue Nov 17, 2015 3:42 pm
Finally had some today and wired them up and sealed too!
What's the easiest way to reduce the photo file size as usual its too big! Annoying! :roll:
by DanSE4 » Tue Nov 17, 2015 6:11 pm
RedCalibra33 wrote:What's the easiest way to reduce the photo file size as usual its too big! Annoying! :roll:
Image resizer tool for W7/8/10 or just create a Photobucket account, upload your pictures to that & then copy/paste the IMG links into your forum posts.
Calibra SE4 3.2 V6 + F28
A Couple of German Cars!
by RedCalibra33 » Tue Nov 17, 2015 6:43 pm
Cheers Dan, didn't realise PB worked here too.
by RedCalibra33 » Tue Nov 17, 2015 6:49 pm
Ready to fit!
Pathetic old style led's in the Sonars! 2 for the entire ring! What a tragic waste of money!
Best place for them! :bazooka:
Users browsing this forum: No registered users and 99 guests
