ABS LIGHT PROBLEMS
ABS LIGHT PROBLEMS
by craigallan12 » Sun Aug 05, 2018 3:55 pm
ABS Light is coming on and off intermittently. A few years ago both front ABS units were replaced. I suspect it must be the rear unit that's at fault. Is this easily repaired by competent DIY man and what would it cost me.?
Thanks for reading.
Craigallan12
Re: ABS LIGHT PROBLEMS
by Callyman » Sun Aug 05, 2018 4:32 pm
Give the abs rings a good clean. Rust or dirt build up can cause this.
by Cliff » Sun Aug 05, 2018 8:32 pm
Check the rings for minor cracks too, another common fault is that as the hubs rust the rust causes the ring to expand and crack. Finally, cabling/wiring. Does it happen when you turn in a particular direction eg always lane changing to the right?
