fault codes
fault codes
Hi all, can anyone put a link up to the list of fault codes that was on the site. I'm think it was vexorg that posted it, I have had a look and can't seem to find it.
Also, can anyone put a link up for the plastic fuel line that some have used to replace the standard fuel pipe.
Thanks.
Thanks.
Re: fault codes
Unfortunately, top buzz seems to have been taken down or expired
Luckily I found a print out I took and stored as PDF.
I’ll try to find a way to rehost this info but until then, i hope this helps.http://cloud.tapatalk.com/s/5fe2334dd3c96/fault_codes.pdf
Re: fault codes
Cliff wrote:Unfortunately, top buzz seems to have been taken down or expired
The links not working Cliff, thanks anyway.
Re: fault codes
Seems like something is wrong with Tapatalk. PM me your email address and I will email to you instead.Phill wrote:Cliff wrote:Unfortunately, top buzz seems to have been taken down or expired
Re: fault codes
Phill wrote:Thanks Cliff, I got the download and its working fine.
