misfirering on boost
missing on boost! Help!
Replace the Plugs, Rotor Arm, HT leads, Dizzy Cap.
You would be amazed at how much these can break down over time.
Admin
markwilliams
I would also strongly recommend that you get the fuelling checked and do it properly... if you are running lean (which can cause this misfire) you are in danger of melted pistons.
Sparks et al are a good start and I was in the middle of this fault finding exercise when cyliners 2 & 3 let go and I was faced with an engine rebuild.
Kieran_Burns
Users browsing this forum: No registered users and 184 guests
