Dodgy tyre wear
by SukySaggi » Fri Nov 05, 2004 2:57 pm
I've got some wierd tyre wear. Had the tracking checked and its spot on.
The wear is on the front tyres. Front drivers side, inner edge wear and front passengers side, outer edge wear.
I assume its got to be the shock or spring or both. Or can it be anything else?
Please help. [img]/sad.gif[/img]
SukySaggi
by Stupink » Fri Nov 05, 2004 3:17 pm
what tyre pressures do you run on what tyre size on what alloys(offset etc etc)..
sounds like you live by a lot of roundabouts, try upping the pressure a bit.
by SukySaggi » Fri Nov 05, 2004 3:22 pm
Tyre pressure 35 all round. Standard Turbo fan alloys. Tyres 205/50 R 16.
Help......
SukySaggi
by Stupink » Fri Nov 05, 2004 6:18 pm
bounce all corners to check the shocks, if they're ok and the springs arnt visibly broken, and a decent 4x4 lazer alignment shows it to be well within spec.. its just your roundabout driving.. hard right handers forcing it onto the outer edge.. what are the actual tread measurements? what sort of difference are we on about? obviously the outer edges are usually less than the middle section.. so measure both outer edges of the tyre to compare them.
by leegsi » Fri Nov 05, 2004 6:36 pm
Also check for worn wheel bearings and ball joints.
I killed a tyre in 3k miles due to a worn wheel bearing (Worn all the way to the canvas)
leegsi
by Robert_Dale » Fri Nov 05, 2004 6:40 pm
Check the bodywork to see if it might have been in a crash, you should get it on a jig but that could get expensive.
check the bodywork for things like running paint etc where it has been resprayed.
Hope you sort it
Rob
Robert_Dale
by carl_freeman » Fri Nov 05, 2004 7:49 pm
sukysaggi,
your front bumper was loose wasnt it, maybe the dammage was done before you replaced it?
or perhaps the new bumper rubs on the wheels?
carl_freeman
by SukySaggi » Mon Nov 08, 2004 11:34 am
Thanks for the advice guys. I shall start investigating.
SukySaggi
by SukySaggi » Fri Nov 12, 2004 2:45 pm
Went to Masterfit and tried to blame them for the wear on the tyres (even though I know its not their fault :twisted: ) They rechecked the alignment and said it was fine (as I already knew they would :twisted: ) So then I asked what was causing the wear?
They checked everything and said;
1. Driver side lower arm. The rubber bits are very soft. :shock:
2. Front driver shock absorber. Could be bent but looks fine. [img]/smile.gif[/img]
3. Front springs. Both fine. :mrgreen:
4. Front shock top mount and bearing. Could be the most likely cause. [img]/sad.gif[/img]
I 've ordered a pair of front shock top mounts and bearings. Can anyone tell me how to change these.
Many thanks for your help so far.
SukySaggi
Users browsing this forum: Google [Bot] and 16 guests
