Camber kit
RE: sunroof knackered... help please
your best way is to fit the springs etc and then see what the camber looks like it also depends what size wheels youve got mines got 17's with a 35mm drop and the camber is ok however when you have a couple of people in the back there is alot of camber so i could probly do witha camber kit myself its one of them things im just not sure what to do really myself, see how it looks mate! [img]/smile.gif[/img]
4x4Turbo
RE: Re: RE: My V6 Roar (vid)
you can buy them from regal autosport or courtney turbo places like that sell them and yes you can get them for the front and back
hope it helps
olly
hope it helps
olly
4x4Turbo
My 8v was dropped 60 and the camber was that far off the inside of my tyre wore like youd never believe. The 16v was dropped 40 and the camber on that wasnt too bad.. Still noticable like but not half as bad on the tyres..
IMO if you want to save money on tyres and do it properly then id get the camber correction done. It will give you better traction too as all your tyre will be in contact with the road as apposed to maybe just 80% of it.
I always thought tho, it was a definate no no lowering a turbo without Camber correction as it puts a lot of strain on the TX box?
Martyn
Martyn
martynlewins
RE: Xado - What you think?
I was under the impression you could only get the camber correcters for the rear, never heard of adjusters for the front? Anyone else?
Vid
RE: Oil / Volt gauge - wire colours on loom
Vid - your not the only one. I too thought they were only available for the rear as the fronts travel up and down not curving in as the rears do!
Maybe I'm wrong though?
FatLadZ
RE: Internet explorer problem HELP!
ive just found it! as in novaneil other post in regals advert for the camber correction bushs it says the fronts bolt on etc this is what has confused me too!!!
4x4Turbo
RE: Goosed alarm
i like the look of the Noltec kit
<a href="http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4514604742" target="_blank">http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...item=4514604742</a>
<a href="http://www.noltecsuspension.com/gmh.htm" target="_blank">http://www.noltecsuspension.com/gmh.htm</a>
FatLadZ
FatLadZ
Users browsing this forum: Google [Bot] and 13 guests
