alarming questions.....
I'm busy wiring a new alarm... a few questions.
I figuered out from the last posts that the central locking is under the drivers foot well. no probs there.
where can I tap into the indicator lights, and also the main engine electrics. the alarm is supposed to let you cut the car out when you want, but I'm not sure which wire to tap into.
I'm sure that all this is in the engine bay, but I'm hoping not because I'll have to get through from the driver cabin.
Anyway... any help would be truly appreciated.
Wabbitt1970
Re: RE: So what
Try the technical guide for installing the remote locking:
<a href="http://www.clubcalibra.net/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=18&page=1" target="_blank">http://www.clubcalibra.net/modules.php?op=...artid=18&page=1</a>
And the instructions that come with the kit, as this says what colour each wire is and where it can be found:
<a href="http://www.clubcalibra.net/modules.php?op=modload&name=Downloads&file=index&req=getit&lid=13" target="_blank">http://www.clubcalibra.net/modules.php?op=...eq=getit&lid=13</a>
The indicator wires are black/green & black/white, and are under the door sill on the passenger side.
I forget the colours of the lock, unlock, & window close wires, but they are also there.
Couldnt tell you about the main engine electrics - sounds far too complicated for me!
HTH! [img]/biggrin.gif[/img]
craigmcd82
excellent. I found the indicator wires in the passenger footwell, and I found the two wires you talked about for the central locking.
My alarm has four configurations for the central locking. Negative Switch, positive switch, negative/positive switch, and a one for air operated locking.
I'm thinking the Black/blue and red/yellow opens the locking when it receives a positive witch, but I'm probably wrong. Any ideas?
Wabbitt1970
Thats right... This has come up before - its negative pulse.
IIRC The red/yellow and black/blue wires just arm the factory alarm...
Im fairly sure the brown/white wire is the unlocking wire which opens the locks when it is earthed.
Dont take my word for it tho - If you want to know for sure, give the helpline a call on 02476 375999. They know what theyre on about and they are really helpful!
:thumb:
:thumb:
craigmcd82
RE: Crashed My Girlfriends MG ZR
The locking colours are brown/white and brown/red and can both be found in the loom coming out of the passenger side door & are neg pulse.
Fuel Pump wire is found in the loom behind the glovebox but im not posting what it is on a public forum for security reasons. Send a pm and I'll be happy to tell you [img]/smile.gif[/img]
alarmbod
RE: Re: RE: Dont ever let ME buy a Turbo...
I pm'd you alarmbod, but haven't had a response. Is it possible that you can email me the locations and colours fo the wires I need to splice to <a href="mailto:Wabbitt1970@hotmail.com">Wabbitt1970@hotmail.com</a>?
Wabbitt1970
RE: Breaking silver Redtop
I dont know if this is helpfull to anyone reading this but;
I fitted my Remote Central Locking kit to my calibra this moring,
To Lock/Unlock the doors your remote locking box will have to have a Negative Switch output,
The wires you need to lock/unlock are located behind the kick panel on the righthand side of the drivers footwell, the two wires you are looking for are a Brown wire with a RED trace on it, and a Brown wire with a WHITE trace, these go into the Central locking box and can be found on its connector coming out of the wring loom. You will see 2 brown/red wires and 2 brown/white wire going into the connector, either of these will be fine. The wire that is Brown with a RED trace is to lock the doors and the Brown with white trace is to unlock. You can get a power supply from the fusebox which is also in the drivers footwell, i got my power supply from the fuse at the bottom right of the fuse box which i think was for the electric windows (dont quote me!), solder onto one of the fuse connector. Get you earth connection from the bolts which hold the orgionla central locking unit in place.
hope this helps someone!
fusion
RE: Jap style bodykit on ebay
thanks fusion... that's helped a lot. I think I'll have a go before new year rears it's ugly head, 'cause my hangover normally lasts about three days into work.
I don't need the indicator wires anymore, because I've wired those to my undercar neons.... looks really cool when you set and unset the alarm. [img]/smile.gif[/img] and you can see it a mile off if the alarm goes off.
Wabbitt1970
how do i know if my alarm is activated?
hijacking this post for a sec***
my bro applied for a job earlier this week to work as a trainee alarm/technichan
did you know you have to be screened?
they wanted a check on criminal history, dvla etc
even going as far back as school
suppose this is relative to the industry as your dealing with security of cars
just something to add [img]/wink.gif[/img]
Enigmatic
