93 headlight on a 95 calibra???
by gremlin » Tue Jan 25, 2005 12:14 am
Does anyone know if a 1993 headlight will fit a 1995 calibra?
I know there is a slight body difference in the two models but are the lights the same??
Thanks in advance
gremlin
by gremlin » Tue Feb 01, 2005 1:32 am
Does no one know if the headlights are the same on all callys??? 91>98 ish????
gremlin
by gremlin » Tue Feb 01, 2005 4:17 pm
Someone must know if they are the same or will fit or if the light is completely different?
gremlin
RE: Vauxhall mats - how to fit??
by SukySaggi » Tue Feb 01, 2005 4:36 pm
I've only got the one cally so i don't know. You could try ringing a main dealer or Autovaux.
SukySaggi
RE: 93 headlight on a 95 calibra???
by SukySaggi » Tue Feb 01, 2005 4:40 pm
SukySaggi
by SukySaggi » Tue Feb 01, 2005 4:49 pm
SukySaggi
by Smurf » Tue Feb 01, 2005 5:12 pm
They'll fit...
Smurf
Re: 93 headlight on a 95 calibra???
by Dan Willis » Fri Feb 04, 2005 2:08 am
My 8V has been upgraded (by Smurf there! ^) to have fogs... so it's living proof [img]/wink.gif[/img]
Dan
by Smurf » Fri Feb 04, 2005 9:52 am
<!--QuoteBegin-willisit+--><div class='quotetop'>(willisit)</div><div class='quotemain'><!--QuoteEBegin-->My 8V has been upgraded (by Smurf there! ^) to have fogs... so it's living proof [img]/wink.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
Yep [img]/biggrin.gif[/img]
1995 car fitted with headlights from one of MickM's old 1993 Calibra Turbo's [img]/biggrin.gif[/img]
Although if I'm honest the upgrade wasn't intentional... I hadn't fit a bulb properly on the original set and it burnt through the plastic surround, thus failing the MOT. So a mad rush to find some replacements led me to Mick [img]/biggrin.gif[/img]
Damn that feels like yesterday but it was almost three years ago now!
Smurf
by Dan Willis » Fri Feb 04, 2005 10:49 am
And they work quite well... I mean, considering that Calibra lights are completely useless [img]/wink.gif[/img]
Dan
by 1llusion » Sat Feb 26, 2005 2:53 am
Only difference is the number off boults you can use to mount the headlight.
But works perfect
And Try HID Xenon and see the ifference, They nay look useless untill youve seen them with HID
1llusion
