Suspension clonk/bang and wobbly sateering dianosis
by AndiSe5 » Tue Jan 25, 2005 8:00 pm
Ive been going mad mental trying to find out whats wrong with my cally for a while now and yesterday i finaly found the problem
I have been experiancing wobbly wheel syndome for 5 months now and no amount of wheel balancing cured it.
Recently the suspension has started to bang and knock and make all sorts of noises.
So i changed the top mount bushes and bearings and the drop linqs.
But no change.
So i had 1 last look and found that the rear wishbone void bushes had collapse and was causing the front wishnbone to knock againsed the subframe, also this had been causing the vibration.
I have replaced the whole lower front wishbones which include new front and rear voidbushs and lower ball join.
No knocking and no more vibration.
Though you would all benifit from this info, as i see alot of vibration and knocking problem posts.
[img]/smile.gif[/img]
AndiSe5
by projectx » Thu Jan 27, 2005 3:56 am
You may be my hero... [img]/smile.gif[/img]
My steering feels like the wheels aren't connected to it very well, so under acceleration or braking particularly, it just kinda wobbles about (the wheel doesn;'t move, but you can feel the wheels wobbling through it).
I often also get loud clonking noises, and can almost guarantee it if I'm reversing into a parking space (i.e. full lock one way, then the other).
Is this the sort of thing you were getting, as a few months back, I changed my track rod ends, front wishbones as they were both knackered, then about a month later this developed, and it's been driving me mad, just gives me no confidence in corners.
Oh, and I know it's not my brakes, discs, pads or wheels.
projectx
RE: Not Happy
by AndiSe5 » Thu Feb 03, 2005 8:31 pm
Projectx:
what u have said sounds exactly the same as what i have, and also gives me no confidence about driving around corners.
AndiSe5
RE: Urgent help needed very strange vibrations
by ROG » Thu Feb 03, 2005 8:35 pm
I had that a few months ago, changed wishbones and antiroll bar links, put a new set of alloys on it and its so smooth now, no bumps, squeeks etc...,till yesterday... now the backs started squeeking on the speedbumps and when i get out or in...time to replace the dampers and bushes at the back.
ROG
Site and club promotion
by projectx » Thu Feb 03, 2005 9:20 pm
Right, I shall have to have a look into this. As I say, I changed both front wishbone arms, and I think they also came with new bushes, but I'm not sure to be honest. Thanks for the info though, at least I've got a plan now [img]/smile.gif[/img]
And just to check, when you say "rear wishbone void bushes"...You mean the bushes at the rear of the wishbones that are on the front of the car, rather than the bushes on any part of the suspension thats on the back half of the car?
If that makes sense [img]/smile.gif[/img]
projectx
by jayl645 » Thu Feb 03, 2005 9:40 pm
i think you've hit the nail on the head with this 1,i also have the same prob,sometimes when i hold the steering wheel strate the cali wobbloes about a bit,and if i take off fast off the lights its crasy im haveing a fight with the wheel to keep in in a strate line,
"replaced the whole lower front wishbones which include new front and rear voidbushs and lower ball join."
how much did this all cost??
jayl645
by Dan Willis » Thu Feb 03, 2005 9:56 pm
That is useful. Thanks!
Dan
RE: NGK sparkplugs on turbo
by ROG » Thu Feb 03, 2005 10:42 pm
i got front wishbones with new balljoints and all the rubber bushes pre installed into them, and the antiroll bar end links both sides for about £50 at the local motor factors, they dont take that long to fit so i wouldnt go to a garage as id be worrying wether theyd done the job properly.
before i had it done if i floored it the car would jiggle from left to right as i accelerated hard ( a bit like ford capris used to )
ROG
Re: Suspension clonk/bang and wobbly sateering dianosis
by jayl645 » Fri Feb 04, 2005 8:10 pm
it sounds the same as mine i think i need to have a look at it tomorrow,
jayl645
by AndiSe5 » Fri Feb 04, 2005 8:39 pm
Project ex: Cost me £45 frm motorfactors trade price.
And yes i mean the bushes at the rear of the wishbones that are on the front of the car.
Im so glad my info has help so many people [img]/smile.gif[/img]
AndiSe5
by projectx » Fri Feb 04, 2005 10:50 pm
Coooool, thanks for confirming. I'll get this checked ASAP. I'm having a couple of bits done next week so will probably get it checked then, and report back. Ta [img]/smile.gif[/img]
projectx
by Furey » Thu Feb 10, 2005 8:21 pm
i can acheive the same effect by lobbing on some pollyurethane bushes all round the front wishbone, right? is replacing the whole wishbone neccicary? ive been getting a simular problem.
by AndiSe5 » Fri Feb 11, 2005 12:06 am
No need to replace the whole arm, you can just replace the bushes.
I found it easyer (lasy) to replace the whoe arm.
1 word of warning though is to be extreamly carefull when putting the rear wishbone bolt/s back in that goes through the subframe and chassis.
As my passengers side stripped the treads clean out when repairing mine.
Only fix was to weld up the hole and drill and retap.
AndiSe5
by 4x4Turbo » Wed Feb 23, 2005 9:33 am
i need to do mine but that has been mentioniod to me that the treads are stripped both sides on mine so im a bit unsure what to do!!
4x4Turbo
by King Calibra » Wed Apr 27, 2005 9:25 pm
This kind of worries me about doing the repair myself. I am having the same problem, and I'm not good at welding, or re-tapping ANYTHING. BTW, where is a good place to order a set of PU bushings?
King Calibra
