is my alarm on its way out ?
RE: Nissan Silvia - needs a bit of work!
Quick question guys...
The standard alarm, when you turn the key to operate the deadlocks should the light on the alarm sensor flash rapidly or should it flash every couple of seconds ?
mine flashes rapidly, ive never noticed it before and am wondering if there is a problem ?
thanks in advance [img]/smile.gif[/img]
Col
RE: Alternator
I cant remember off the top of my head - But hopefully this will help!
craigmcd82
hmmm. cool info. mine flashes repeatedly for the first 10 seconds and does not change even if i press the button on the cabin sensor. i suppose it is due to the bonnet switch missing. will put a switch in the bonnet and give it another try.
does anyone have pictures for the rest of the sensors please? where are the door alarm switches located? are they the same switches that put out the interior light when the door is closed?
also i took my car to a professional to install a new radio system. i think i've read in your manual that the alarm is monitoring also the radio. is it possible that there is an error there too now?
tb303
hi,my led flashes with in the first 10 sec's i think it has a fault!!!,could it be the drivers door sencor because the interior light dosent come on when i oped the door but it works with the passenger side?,
and is there ment to be any thing behind the interior light as i have a round hole in my head liner about the size of a 50 pence piece,(strange) any help would be great as i need to get it fixed asap,
chears jay any quick fixes would be good
jayl645
RE: LEAK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Short pins A and H on the diagnostic plug and it should flash out the fault codes to any problems on the LED
What Size R They
hi.. 33 means that the bonnet switch triggered the alarm.. you should be able to clear the code with the button on the ultrasonic unit... if it keeps re appeearing i guess there is sommit wrong with the bonnet switch/wiring [img]/smile.gif[/img]
02 voicemail
the code is 33 for the alarm i did set the alarm off by the bonnet switch today!!! ill press the button and try it again,thanks
do u know what the code 31 and 12 means(not for the alarm)i put a paper clip in a+b chears
jay
jay
jayl645
RE: 02 voicemail
thanks so i dont need to do anything about 31? (its normal) i thought it was guna cost a bomb
jayl645
Users browsing this forum: Bing [Bot] and 33 guests
