Wolfrace Ikon Plus 18's - will they fit?
Hi all,
Been offered a set of 18" Wolfrace Ikon Plus wheels - they were off a BMW Mini - will they fit my car?
I have a 92 Redtop - The wheels are ET38 - and the PCD is 4 x 100 - which is all OK (I think?)
Is there any other measurements that I should check before I buy them?
Any help would be great.
Cheers everyone,
Adam.
Cheers everyone,
Adam.
wardyworld
The centre bore is the diameter of the hub lip that the wheel locates on. It centralises the wheel and makes it easier for you to get the wheel bolts lined up. As the mini wheels cente bore is bigger you can just get some spiggot rings (there the plastic ring inserts you get with aftermarket wheels) to suit.
Peachperformance
<!--QuoteBegin-Peachperformance+--><div class='quotetop'>(Peachperformance)</div><div class='quotemain'><!--QuoteEBegin-->ET 38 with 215/35/18 tyres on mine and no problems [img]/smile.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
Cheers for the reply peachperformance - am looking into Spigot Ring suppliers now...
Can I ask how the ride is with 18's?? Mine will be almost identical to yours - so just wondered?
I have 17's and they do tend to tramline a bit - meaning you must always grip the wheel as the car can suddenly pull towards the roads camber..
Cheers,
Adam.
Cheers,
Adam.
wardyworld
<!--QuoteBegin-wardyworld+--><div class='quotetop'>(wardyworld)</div><div class='quotemain'><!--QuoteEBegin-->Hi all,
Cheers everyone,
Adam.<!--QuoteEnd--></div><!--QuoteEEnd-->
YES they fit, i have them very exact ones on my calibra apart from mine are chrome (bling)
Cheers everyone,
AndiSe5
<!--QuoteBegin-wardyworld+--><div class='quotetop'>(wardyworld)</div><div class='quotemain'><!--QuoteEBegin-->Cheers for the reply peachperformance - am looking into Spigot Ring suppliers now...
Cheers,
No problem mate [img]/smile.gif[/img] .
The last time i bought some spigot rings seperate from the wheels I got the from Wheelmania so you could give them a try.
I do get some tramlining from the wheels but it isn't as bad as the 100+ 17" tornados that were on it before and the roads round here are crap so I don't think you'll have any worries
Cheers,
Peachperformance
