Quick PAS question....
by noelboy » Mon Mar 14, 2005 1:27 pm
Can I fit the reservoir bottle from a Turbo to a 2wd 16v?
My current bottle looks different but will it do any harm to fit it?
noelboy
by Rusty_CallyT » Mon Mar 14, 2005 1:42 pm
dont know if u can as i got a feeling theres extra outlets on the res for the txb etc... might be wrong tho
Rusty_CallyT
by noelboy » Mon Mar 14, 2005 1:51 pm
Looking at it it's got two outlets on the bottom...1 larger then the other
noelboy
by noelboy » Mon Mar 14, 2005 9:29 pm
Anyone?
noelboy
by Millard » Thu Mar 17, 2005 11:51 pm
I have another PAS question, when i turn my steering wheel slowly it makes a grinding noise and i get some resistance. Is this because of the pump or is it something more serious?
Millard
by Stupink » Fri Mar 18, 2005 12:23 am
dunno about the bottle internals, might be ok if you block off the accumulator return one on the turbo bottle..
grinding doesnt sound good mate, check your fluid levels, if they're ok then get it looked at, coudl be the rack/pump/suspension turret bearings etc etc.. get the front off the ground and try it, see if it works smoothly as it should, might give a clue.
by Millard » Fri Mar 18, 2005 12:29 am
Cheers. It doesn't do it when i drive on gravel.
Millard
by projectx » Sat Mar 19, 2005 10:28 am
Not to be picky, but when you say grinding, do you mean whining?
I've had this from either not having quite enough fluid in the resevoir, and also when the belt that drives the pump was slipping a bit, though therre are obviously worse consequences than those two things.
projectx
by Mark1 » Sat Mar 19, 2005 10:41 am
<!--QuoteBegin-Millard+--><div class='quotetop'>(Millard)</div><div class='quotemain'><!--QuoteEBegin-->I have another PAS question, when i turn my steering wheel slowly it makes a grinding noise and i get some resistance. Is this because of the pump or is it something more serious?<!--QuoteEnd--></div><!--QuoteEEnd-->
It may be because your dry steering(the cars not moving).
